20 Most Recent Vizio VA26L 26 in. LCD HDTV Questions & Answers
2answers
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button. Instructions 1 Turn on the Vizio TV. 2 Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on. 3 Press the "TV" button at the top of the Jumbo Universal Remote. 4 Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV) 5 Press "Enter" on the remote immediately after the Vizio TV turns off to save the code. 6 Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
10/12/2023 4:44:49 PM • Vizio VA26L 26... • Answered on Oct 12, 2023
2answers
Cracked screen
It will be more than what the TV is worth. Check here to get some ideas how much they go for: www.shopjimmy.com
3/9/2023 9:57:43 PM • Vizio VA26L 26... • Answered on Mar 09, 2023
My tv stuck in the photo menu and i dont have a remote, side buttons stoped working how to rest tv to main screen
Turn it on while holding the menu button on the side at the same time and hold it
5/10/2022 10:56:19 AM • Vizio VA26L 26... • Answered on May 10, 2022
Remote wont work
Check the batteries first.
7/4/2016 4:05:28 AM • Vizio VA26L 26... • Answered on Jul 04, 2016
Remote does not work. I have changed batteries twice - yet remote has red light with no response from the TV. Thanks
You can test the remote control using a camera to see if the remote is transmitting the IR signal. Place the remote control in front of camera and press any button, once you press the buttons you should see the LED on the remote emitting a light but that is only visible on the camera. If no light is visible, then the remote control is defective.. If light is light is present, then is IR receiver on the TV is defective. Let me know if you require further assistance.
8/24/2015 2:31:02 AM • Vizio VA26L 26... • Answered on Aug 24, 2015
Vizio TV. Can't get out of PHOTO mode. I have no remote. Side MENU button doesn't respond when in PHOTO mode. Need to Hard Reset... How can I?
^_^ Those answers are only for new remote but that's not the only way, There trying to ask in another way with out a remote.
12/24/2014 10:16:26 PM • Vizio VA26L 26... • Answered on Dec 24, 2014
Como puedo quitar el modo de demostraci&#243;n de una tv vizio
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
9/18/2014 8:56:00 AM • Vizio VA26L 26... • Answered on Sep 18, 2014
Why doesnt my vizio fllatt screen have and on and off button
It does. It will be a touch sensitive button on the face of the unit (lower right hand corner) or a button under the center front.
6/2/2014 1:17:40 AM • Vizio VA26L 26... • Answered on Jun 02, 2014
0answers
What is a digital tuner how it looks like
852f9a27-2939-45de-b8ac-78123e213799.jpgIt will look somehat like this
9/23/2013 3:23:09 PM • Vizio VA26L 26... • Answered on Sep 23, 2013
Vizio pixelation in hd nt all channels
Usually a TV that pixelates only on some channels is a problem with the signal levels coming into the TV or the cable box. If you are using a cable box then definatley the signal is the issue..
9/22/2013 7:12:23 PM • Vizio VA26L 26... • Answered on Sep 22, 2013
My vizio va26L is stuck in photo mode and I don't
Many electronic devices today can be reset by unplugging the power cord and waiting 2 to 5 minutes and then plug the power cord back in.
8/25/2013 5:20:15 PM • Vizio VA26L 26... • Answered on Aug 25, 2013
2answers
My vizio worked fine and then it will not turn on unless the manual button is pushed and held numerous times. once on the remote works fine and can turn off. any cheap or easy remedy?
could be just bad capacitors on the power supply board they tend to puff up on top and then several attempts of pressing the power buitton is required to finally get the set to power up.
2/3/2013 2:28:53 AM • Vizio VA26L 26... • Answered on Feb 03, 2013
Vizio VA26L 26 in. LCD HDTV Logo
144 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VA Vizio
  • VA Vizio
Most Popular Question
need code vizio tv bought ihip remote
  • Televison & Video
