20 Most Recent Kenmore 300 Series Water Softener Questions & Answers
I have a kenmore frontload washer model 417.48102. It just stopped spinning and shut down. I turn it back on, it will do everything until it needs to spin then shuts down. Why does it shut down when i
My guess is the door switch is a two part switch, and one is controling the spin cycle, the other works cause it does everything else..
6/5/2014 11:50:39 AM • Kenmore 300... • Answered on Jun 05, 2014
Error Code 1
The fastest I ever saw a Kenmore softener thrown in the dump was seven weeks old. This was at the owner's insistence; just wouldn't remove iron. He bought an Autotrol with a turbulator from me. This was about 15 years ago and it still works just fine. He had his first service call 2 years ago. I've always thought that quality was more important than price, but if you wish to install yourself I can come so close to the "sale" price of a Kenmore.
5/28/2014 11:25:37 AM • Kenmore 300... • Answered on May 28, 2014
Managemylife com
Kenmore Dryer model # 110.87081601 recently received the console control mojule(where the control button are). their parts person told me this probally was my problem. did not work. the dryer is making a clinking sound like a relay is not working. The cabnet control modjule pictured does not match the pictures on the parts list. the cabnet control modjule pictured does not have any relays nor does it have the higher voltage wires. the one not pictured does. would you say a clicking relay and no results might be the problem and if so, i probally need to call sears and talk with a supervisor? Or is there something else?
3/16/2014 5:19:17 PM • Kenmore 300... • Answered on Mar 16, 2014
3answers
Is there a reset procedure on a Pedrollo DG5 variable speed, soft start water pump, after a power cut?
A WELL PUMP, THE LIFT LIMIT IS Max. suction lift 8m EXCEED THAT AND IT FAILS. GET THE USERS MANUAL FROM THE MAKER IF STILL HAVE PROBLEM ASK THEM FOR HELP THE MANUAL TELLS YOU HOW PRIME THE PUMP' WHY NOT JUST READ IT FIRST THE FREE PED 5 IS HERE https://www.manualslib.com/products/Pedrollo-Dg-Ped-5-11635754.html THE MANUAL IS FULL OF TROUBLESHOOTING IDEAS PRIME: THE MAKERS WEB SITE HAS A MANUAL PED 5 https://www.pedrollo.com/public/manuali/DG%20PED_EN_Manual.pdf
2/14/2024 11:56:48 PM • Water Dispensing... • Answered on Feb 14, 2024
Myers 7600 softener manual please?
Question edited for clarity, correct order and spelling (softner). Question moved from Office Equipment. Unfortunately it doesn't appear to exist anywhere online here in North . https://www.google.com/search?q=Myers+7600+softener+manual ..
2/8/2024 11:24:12 PM • Water Dispensing... • Answered on Feb 08, 2024
I have a Vitapur VWD9506BLS and the reservoir is not auto filling how do I fix it?
Vitapur VWD9506BLS download instruction manual pdf
10/6/2023 5:58:41 PM • Water Dispensing... • Answered on Oct 06, 2023
I have a Monarch Water softener Midi 7E. It is constantly filling up with water. Can you help?
Question moved from Washing Machines category. Help here plus the Service Manual. A plugged Injector seems the most likely reason. https://www.google.com/search?q=Monarch+Water+softener+Midi+7E.+It+is+constantly+filling+up+with+water ..
9/5/2023 5:44:59 PM • Water Dispensing... • Answered on Sep 05, 2023
Kinetico Quad 50 troubleshoot or replace?
it's not a car or truck so moved you to water filters call 3 plumbers, get 3 quotes. as grand dad said and is 100 % right. learn to do your own shopping, and quotes./ nobody here can inspect any thing like that deeps inside, nobody. ( no bore cam photo's x 25 presented) ask only the living, hands on plumbing techs. some do if for free even, (diagnosis or small charge) ask the living not the blind. what does BETTER mean, ask 10 persons get 10 answers to that I'd by pass it and and send it to the dumps,. if was here. our water is clean here, USA> (no lead pipe here) the water tests here pass all tests. by wide margins !!! 100% safe. to be frank, I do not trust things like that in my home. as it can be nasty inside ,and be unseen by me. ( noodle that?) even if you go on long vacations it can get nasty inside. yes it is too old or get more quotes. or bypass it, or upgrade it or go ROS, reverse osmosis.sys.. ROS wastes lots of water, maybe banned in CALIF. IDK
10/18/2022 3:38:55 PM • Water Dispensing... • Answered on Oct 18, 2022
2answers
The question I ask on may 30 and answered, but my husband said water pipe under road was not metal. Said it was a blue pipe.
Posting follow-ups as a new post doesn't work here on Fixya because posts are not threaded by poster or subject. This post has no context to your previous post. This should be posted under my Comment as it was me that answered you. And you posted to the category 'Cars and Trucks'. https://www.fixya.com/support/t29875597-after_building_new_house_master_bathroom Unless you are in a new division, connect to a new water main, there will be cast iron pipe that was cut and joined to the blue PEX Pipe. The answer is the same, contact your water supplier. Put samples in clear glass containers or jars and show them. It is their duty to provide you with clean water.
6/2/2022 12:37:32 AM • Water Dispensing... • Answered on Jun 02, 2022
We didn't have heat for more than a week and shut the water off and on and now the water softener had a lot of water in it and we don't know if it works. Is there a way to check?
Question moved from Washing Machines category. Water softeners add a small amount of water to dissolve the salt. You can just remove some of the water from it. https://www.google.com/search?q=how+water+softener+works+animation ..
2/23/2022 11:55:21 PM • Water Dispensing... • Answered on Feb 23, 2022
I have a Kenmore elite 520 water softener filled with water will not drain out this is a water softener not a washing machine.
go here, or you may be money ahead to replace it. I repaired mine spent money on parts. Replaced it with one from HD salt consumption is about 1/10 of kenmore
11/9/2021 5:03:33 PM • Water Dispensing... • Answered on Nov 09, 2021
My new vitapur bottom load water dispenser is not coming on at all like I don't hear the motor even running what can I do?
If the water is the appropriate temperature it is OK. If not take it back.
10/2/2021 4:35:27 AM • Water Dispensing... • Answered on Oct 02, 2021
The new Nikai water dispenser doesn't make hot water
It sound like it is not properly wired. The earth wire must be connected for your safety. Also what is the voltage on the nameplate verses what you connected it to.
10/2/2021 2:44:40 AM • Water Dispensing... • Answered on Oct 02, 2021
Ceramic water dispenser overflows
Contact the maker of this mystery water bottle dispenser. It sounds like it needs replacing under warranty. However..... SOLUTION by OP: there was a hairline crack that did not show up until the plastic water bottle was inverted & the pressure /exchange between both bottle & crock caused enough "pull" to cause spillover the top of the crock. I have a secondary polycarb bottle (3gal) which is working perfectly. Simple physics, once again..
5/26/2021 3:32:16 PM • Water Dispensing... • Answered on May 26, 2021
My waterwise distiller 3200 light turns on flashes then turns off
Hi Frances, hope you are well and safe, Please have a look at the given solution. To turn Distiller on or off, press the "Start/Stop" button. When turning Distiller on, "On" appears in the display window and the "On" (red) light illuminates (fig. B). After turning Distiller off, the "On" light turns off.
12/3/2020 12:06:10 PM • Water Dispensing... • Answered on Dec 03, 2020
How to remove head off resin tank on culligan mark 89
It screws on to the tank. Make sure to relieve water psi. Turn the water off first.
11/14/2020 4:46:54 AM • Water Dispensing... • Answered on Nov 14, 2020
What is a water distiller?
A water distiller is a device that removes most impurities from water, through distillation. Distillation means boiling the water and then collecting the condensed steam into a clean container.
3/15/2020 2:01:59 AM • Water Dispensing... • Answered on Mar 15, 2020
Kenmore 300 Series Water Softener Logo
36 questions posted
Top Kenmore Water Dispensing & Filtration Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Kenmore Water Dispensing and Filtration Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Water Dispensing & Filtration
Most Popular Question
  • Water Dispensing & Filtration
