20 Most Recent Amigo HD450 3-Wheel Scooter w/33AH Batteries - Color Cinnamon Red - Value M Questions & Answers
Control module smoked !
what about calling the people who made the scooter and ask them for help. also if you can not afford a new one sometimes community groups like Rotary or the Lions club will sponsor life aids, especially for younger people they are all about good quality of life! give it a try, nothing to loose and you might just get a new scooter! hope it helps.
11/29/2017 1:44:32 AM • Amigo HD450... • Answered on Nov 29, 2017
0answers
Not getting power from battery to handle-bars
could be the key switch or the flat cable that runs from the controller to the bottom of the throttle assy.
5/3/2014 1:48:12 PM • Amigo HD450... • Answered on May 03, 2014
I have a Fiesta by Amigo, When I turn the switch
check here there are different codeshttp://myamigo.com/amigo-mobility-scooters-support/amigo-mobility-scooters-owners-manuals.html?download=20%3Aamigo-rtexpressjunior-amigo-rd-amigo-ext350-amigo-hd450-amigo-mc-amigo-mcx-2003-present
11/1/2013 3:29:48 AM • Amigo HD450... • Answered on Nov 01, 2013
Where is the serial number
normally at the bottom of the steering column it there's o boot look under itor in the battery compartment next to the batteries
11/1/2013 3:20:32 AM • Amigo HD450... • Answered on Nov 01, 2013
I bought an older Amigo
look on the inside of the wheel there should be bolt and nut going thru the wheel and axle you'll need a long Allen wrench and nut driver to remove and the wheel pulls offsorry not sure what size wrenches
11/1/2013 3:14:25 AM • Amigo HD450... • Answered on Nov 01, 2013
Battery fully charged wii not run
Hi. We need a bit more info. Any lights flashing, if so how many flashes between the pauses.
Have you checked the free-wheel lever is in the correct position?
Did the machine suddenly become faulty, or has it had faults for a while?
Good luck. Neil.
7/13/2010 9:21:05 AM • Amigo HD450... • Answered on Jul 13, 2010
What do you do if you find a grocery amigo mobility cart
I would telephone the store as if stolen/lost, they will retreive it.
11/4/2022 7:15:46 PM • Amigo Health &... • Answered on Nov 04, 2022
My amigo smart shopper goes fine for a few seconds then stops and beeps
Hi, please use your manual to diagnose the cause of the beeping issue and the corresponding solution. If you don't have a copy, please call the manufacturer at 800-248-9131 . Thank you.
10/1/2022 10:41:34 PM • Amigo Health &... • Answered on Oct 01, 2022
How do i connect my amigo value shopper batteries. There is 2 of them.
Contact Amigo to request instructions.
11/11/2020 1:29:45 AM • Amigo Health &... • Answered on Nov 11, 2020
,Y SCOOTER MAKES A HIGH PITCH NOISE WHEBN THE KEY IS ON OR WHILE CHARGEING WHAT CAN BE WRONG WITH MY SCOOTER
I give the same answer to all noise questions, have someone listen, I can't from here.
9/21/2016 10:50:38 PM • Amigo Health &... • Answered on Sep 21, 2016
2answers
Have a amigo smart shopper scooter and "dead man" switch apparently not working correctly. When I depress thottle, scooter goes forward without any weight on seat?
need to know how old unit is smart shoppers now use seat switches that are normally open without weight and when seated normally closed, if you unplug the wires that come from the seat switch and the cart doesn't move then the seat switch is stuck and should be replaced. older units were normally closed without weight and normally open when seated in this case check to see if the wires have come unplugged and reconnect them then recheck if cart won't run when seated replace seat switch.
4/22/2015 2:23:15 AM • Amigo Health &... • Answered on Apr 22, 2015
Amigo handicap scooter -- loosing distance with in use
you'll need new batteries plan on replacing them at 1-1/2 to 2 years
4/17/2015 12:57:25 PM • Amigo Health &... • Answered on Apr 17, 2015
Scooter will not go.
Have you checked the batteries
3/16/2015 1:00:00 AM • Amigo Health &... • Answered on Mar 16, 2015
I have an amigo RT,
check the charger, if you plug it in the indicator should blink for aprox. 30 sec. then go solid and when charge is complete the indicator will start to blink again, also if the charger is working the scooter should not move when plugged in, if charger not working check power cord before replacing charger
3/16/2015 12:59:18 AM • Amigo Health &... • Answered on Mar 16, 2015
Where are settings on amigo smart shopper
In the motor controller and depending on the age may or may not be adjustable without a programmer
3/16/2015 12:52:14 AM • Amigo Health &... • Answered on Mar 16, 2015
I want to reprogram an Amigo Value Shopper to have a faster top speed
Sorry but you would need a programmer to attach to the controller I am a service tech and use it to program the controllers
3/16/2015 12:50:28 AM • Amigo Health &... • Answered on Mar 16, 2015
Amigo HD450 3-Wheel Scooter w/33AH Batteries - Color Cinnamon Red - Value M Logo
10 questions posted
Top Amigo Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Amigo Health & Beauty
Most Popular Question
control module smoked
  • Health & Beauty
