20 Most Recent Inverter KEB COMBIVERT F5 Questions & Answers
What is cable breakage at the resolver or incremental encoder
It means that the signals between the inverter and feedback device are being lost. This is due to a cable breakage, defective encoder/resolver, or loose connection, possible defective feedback card.
4/1/2024 3:02:53 AM • Inverter KEB... • Answered on Apr 01, 2024
2answers
Power unit not ready
Do you mean no_Pu error? Reason for error = 24Vdc is being applied to the control card but the mains voltage is not being applied to the power stage.
10/14/2022 11:28:02 AM • Inverter KEB... • Answered on Oct 14, 2022
I have a keb F4 how i can have the factory setting
Registered users on the KEB website have access to the manuals which will provide details on programming the inverters.
8/2/2022 9:10:39 AM • Inverter KEB... • Answered on Aug 02, 2022
E.up and eoc always occurs,what
E.UP = Under voltage Check your supply voltage. E.OC = Over current Check for shorts between the inverter and motor.
7/2/2019 6:51:16 AM • Inverter KEB... • Answered on Jul 02, 2019
Inverter IGBT failuair again& again
If you are continually replacing the inverters, there may be an external issue causing the failures. If you are continually replacing IGBT's on the same inverter, then there is most likely a problem with the circuit controlling the IGBT's.
7/23/2018 8:21:02 AM • Inverter KEB... • Answered on Jul 23, 2018
No_pu on keb combivert
Please see:
2/1/2018 3:52:30 PM • Inverter KEB... • Answered on Feb 01, 2018
Inverter keb combivert f5
What is the actual problem you are having?
7/4/2017 10:48:23 AM • Inverter KEB... • Answered on Jul 04, 2017
tip
KEB COMBIVERT F5 help
When ever you have a questions about a KEB Combivert inverter, it is best to provide as much information as possible. At a minimum provide the following: Part# or art-nr Serial # or ser-nr Fault codes Type of machine Machine manufacture Problem description KEB manufactures many different types of F5 inverters and each type has different hardware, software and functionality. With the above information it is easier to provide a better solution to the problem.
I have a KEB combivert F5. The parameter ru 00 shows nop even if i give switching to terminal 16 for control release.Please help.
This may be due to the inverter waiting for an ST signal via buss communications. What is the part # of the unit in question? The inverter is recognizing that terminal 16 is going active but still waiting for another command to enable the inverter.
2/18/2017 10:37:29 AM • Inverter KEB... • Answered on Feb 18, 2017
KEB 07 F5 Error code E. Puch what will cause this error and how do i clear it
E.puch means that at power up the control card did recognized the power stage as different than last time it powered up. This is normal when the control card is changed. If the control card has not been changed, there is a problem between the power stage and the control card. Initialize the value at sy.03 to reset the error.
11/17/2016 3:11:20 PM • Inverter KEB... • Answered on Nov 17, 2016
I have a keb inverter for c51 carding machine new I need to make it start
I would guess that this is off of a Rieter machine (C51 Carding Machine). They would be your best source of information. Verify that the unit is properly programmed and that the control wires are correct.
7/25/2016 7:23:06 PM • Inverter KEB... • Answered on Jul 25, 2016
What does OL2 fault in KEB drive indicate?
Too much current is being required with the motor shaft not rotating. This is most likely a parameter adjustment issue with the motor data, torque limits and protective functions. Possible motor issue as well.
7/25/2016 7:20:32 PM • Inverter KEB... • Answered on Jul 25, 2016
What is no_PO error
no_PU = No power unit. 24Vdc is being supplied to the control card with no AC voltage (230 or 400) being supplied to L1/L2/L3. Verify AC voltage is present at L1/L2/L3. *If not present, apply voltage and no_PU should clear. *If present and unit still no_PU, there is a problem with the power stage. At that point unit should be replaced or repaired.
7/25/2016 7:15:44 PM • Inverter KEB... • Answered on Jul 25, 2016
How to save the parameters in KEB F5
Here is how to use the keypad. If a decimal shows up after the value is changed, enter must be pressed to save the value. Also insure that the inverter is not enabled or in nOP status.
7/25/2016 7:09:22 PM • Inverter KEB... • Answered on Jul 25, 2016
Inverter faults every 15 - 20 minutes
With out knowing what the error codes are that are being displayed, it is impossible to provide a solution.
5/21/2016 12:02:01 AM • Inverter KEB... • Answered on May 21, 2016
The inverter not work and all signals good
Verify the mains voltage at terminals L1/L2/L3. If it is present but the inverter does not power up, there is most likely an internal problem. What is the part# of the unit in question?
4/18/2016 1:06:14 PM • Inverter KEB... • Answered on Apr 18, 2016
Vmi fault coming up
Vmi is not a KEB fault code.
6/3/2015 2:48:31 PM • Inverter KEB... • Answered on Jun 03, 2015
General fault 142
The does not appear to be a KEB error code.
6/3/2015 2:47:45 PM • Inverter KEB... • Answered on Jun 03, 2015
General fault 142error
This does not appear to be a KEB error code. If this code is on on your HMI, contact the machine manufacture to determine what this error means.
6/3/2015 2:45:19 PM • Inverter KEB... • Answered on Jun 03, 2015
2answers
Always showing alarm EOC,EOP
The system that you described is a closed-loop system. The inverter tells the motor what to do and the encoder send information back to the inverter to verify the operations. With out knowing part# and serial number of the unit in question, I do not know exactly which inverter you are having problems with. With E.OC error, there is a lot of current demand on the inverter. This could mean a short in the motor, motor leads, connections or inside of the inverter. This could also be caused by the encoder feedback loop being defective. If the inverter tells the motor to run at 1000rpm and the feedback tells the inverter it is only running at 5rpm, the inverter will send out more current to get the motor up to speed. Since you are getting multiple errors, there could be other internal problems with the inverter especially if the unit is old and contaminated internally.
6/3/2015 2:42:26 PM • Inverter KEB... • Answered on Jun 03, 2015
Inverter KEB COMBIVERT F5 Logo
132 questions posted
Top Inverter Electronics - Others Experts
Ngoro
john h
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Inverter Electronics - Others
Most Popular Question
no po error
  • Electronics - Others
