20 Most Recent Homelite ZR10926 16 Chain Saw Questions & Answers
I have a UT10947D Homelite chainsaw that uses
check that you are using chain bar oil and not engine oil as that is the main reason for excessive oil usage make sure that there is the small restriction at the exit point if that is missing , then that will be your problem
10/18/2017 7:47:15 AM • Homelite ZR10926... • Answered on Oct 18, 2017
2answers
I cannot locate my owners
most 2 stroke Homelite chainsaws run on a fuel/oil mix of 50:1 --- But on some older model saws they say to use 40:1 mix.
I own several 2 stroke machines and I use 50:1 on everything and they all run fine ( even when they say 40:1 ).
c...
2/16/2015 3:56:16 PM • Homelite ZR10926... • Answered on Feb 16, 2015
Switch turns off
try pulling the starting rope a little bit out before you pull start it. If this does not work replace the switch.
9/8/2014 6:31:04 AM • Homelite ZR10926... • Answered on Sep 08, 2014
The chain on my chainsaw
if the chain wont turn your clutch is the problem
3/4/2014 3:16:29 AM • Homelite ZR10926... • Answered on Mar 04, 2014
Homelite chain saw XL925 cord pull too hard but if
I have a Homelite XL and was having problems with rope pulling from difficult to unable to pull rope while trying to start saw. I removed the muffler, squirted some WD40 through the exhaust port ABOVE and BELOW the piston compression ring. Then pulled the rope about 20 times without spark plug to fully lubricate the piston and cylinder. Left it till the next day, pulled it through about 20 more times, put the spark plug back in,and it works well now. Guess it was just gummed-up a little and the lubrication freed it.
12/2/2013 12:33:23 AM • Homelite ZR10926... • Answered on Dec 02, 2013
How to check chainsaw for problems
Adjust idle, Adjust fuel/air mixture screw, check for clogged fuel filter/line, Take carb apart and clean all ports and screens.
11/21/2013 5:24:44 PM • Homelite ZR10926... • Answered on Nov 21, 2013
2answers
My Homelite ZR10926 16-Inch 33cc
It probably is not getting enough fuel. Check the filter in the tank. If it has been sitting with stale gass this filter plugs up.
Try running the engine with some choke. If this helps, try adjusting the carburetor high speed screw.
10/7/2013 9:09:48 PM • Homelite ZR10926... • Answered on Oct 07, 2013
Chainsaw will not idle homelite
Any more info?
2/22/2013 11:36:53 PM • Homelite ZR10926... • Answered on Feb 22, 2013
2answers
What is the best oil:gas ratio for this chain saw?
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
9/16/2012 11:33:01 AM • Homelite ZR10926... • Answered on Sep 16, 2012
4answers
My Homelite Ranger 16 inch chainsaw starts great
My 16" Ranger had the same problem. Here's how to fix it. Take off the top cover and the red side cover to acess the carburator. Take the top off the carb; there is a single screw that holds it on. Inside you will see a 10mm round indention. This is a final screen fuel filter. Mine had a layer of light brown dirt over the screen. Take a small screwdriver and carefully scrape the dirt off. You don't need to clean the carb any further or adjust the H and L settings or anything. Put it back together and it should run with no bogging. down.
8/10/2012 10:38:08 PM • Homelite ZR10926... • Answered on Aug 10, 2012
Cylinder compression
look on the side of the cylinder for the compression release valve
5/8/2012 1:47:05 AM • Homelite ZR10926... • Answered on May 08, 2012
Homelite ZR10926 16 Chain Saw Logo
155 questions posted
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
View Most Popular
Homelite Garden
  • Homelite Garden
Most Popular Question
having problems
  • Garden
