20 Most Recent Bench Factory-Reconditioned Ryobi 2.1 Amp, 6" Grinder ZRBGH616 Questions & Answers
2answers
I have a Ryobi BGH615 bench grinder. I've had it
replace the start/run capacitor or repair the centrifugal stating device in the end of the unit
11/7/2017 8:38:23 PM • Bench... • Answered on Nov 07, 2017
Where can I get a FA3-4 Ryobi grinder on/off
try radio shack,or electronics store in your area
6/14/2009 3:03:58 PM • Bench... • Answered on Jun 14, 2009
Cummins model C-140 Bench Grinder. Can I get an owners manual please?
There is a similar one on eBay, but no free ones. Cummins are known for diesel engines rather than grinders, which means someone else made it and put a Cummins badge on it. Take your pick from any of these. https://www.google.com/search?q=8%22+Bench+Grinder+manual They don't need much of a manual anyway, most of the content is on safety. Press switch to turn on and off, one arbor is right hand thread, the other is left hand thread. https://www.google.com/search?q=Cummins+model+c-140+bench+grinder+manual ..
7/12/2023 3:45:58 PM • Bench Grinders • Answered on Jul 12, 2023
Bench grinder need the rite wiring conection please
replace the starting cap
10/19/2021 1:58:47 PM • Bench Grinders • Answered on Oct 19, 2021
2answers
Nutool bench grinder/sander is it possible to get a manual for this machine it is a NTG6L-4.
Contact Nutool directly to inquire.
1/19/2021 12:01:14 PM • Bench Grinders • Answered on Jan 19, 2021
Wiring diagram for power pro craft 6 " bench grinder
Contact Power Pro Craft directly to request the wiring diagram.
1/18/2021 3:25:01 PM • Bench Grinders • Answered on Jan 18, 2021
I have a Buffalo Model B-8 bench grinder and am looking for a wire wheel attachment. This grinder was purchased in 1982. Not finding comparable parts anywhere.
A wire wheel is bought from the same sort of supplier as you would buy a grinding wheel. The dimensions of the wire wheel should be similar to the grinding wheel it replaces, though the centre hole is usually larger and should be fitted and mounted with the correct size plastic bushes and steel retaining washers. The guard and the tool rest should not be used with a wire wheel for safety and of course there should be a hook nearby to hang a pair of safety goggles... Bear in mind, in a commercial environment, local legislation could exist that means only a suitably qualified and registered person is allowed to maintain/adjust a grinder as in the UK and Europe.
10/22/2020 10:14:08 PM • Bench Grinders • Answered on Oct 22, 2020
I have a buffalo 6 inch dual wheel bench grinder cord and off on switch are missing how do i hook up the grinder is old and has 4 wires
Usually, 4 wires are multi-directional neutral and earth are usually colours the other 2 are both live and would need to go through a switch. you can of course put the other live in a cover and just use one live wired as usual into a plug. Make sure the spare wire is well protected ie in a jb with plenty of tape around it
9/13/2019 6:50:21 AM • Bench Grinders • Answered on Sep 13, 2019
I need manual. For ctt tools 6 in bench grinder model #ct-6b please
I didn't find a manual when I searched. A similar model for sale shows a vender site, where you might ask the question of whether a manual could be provided to you. https://www.amazon.com/sp?_encoding=UTF8&asin=B0057PLTL2&isAmazonFulfilled=0&isCBA=&marketplaceID=ATVPDKIKX0DER&orderID=&seller=A1DXFJTFV58TSS&tab=&vasStoreID=
9/13/2019 6:49:43 AM • Bench Grinders • Answered on Sep 13, 2019
Replacement parts for Central Machinery 8" bench grinder item #39798
Depends what parts are needed. Spare parts for something that goes wrong so rarely can be difficult especially if the machine is imported. Some parts will be fairly universal and so fairly easy to obtain - nuts, flanges, abrasive wheels, bearings, capacitor (if fitted) and possibly even the switch and tool rests.
5/26/2019 11:32:15 PM • Bench Grinders • Answered on May 26, 2019
I need an on/off switch for a dura craft bench grinder model # 506Rx-G
Quick fix..eliminate switch and hook it up direct. Plug it into a cheap power bar that has an overload switch. Use THAT switch to control on/off on grinder
11/8/2018 2:50:13 PM • Bench Grinders • Answered on Nov 08, 2018
2answers
Replace missing switch on bench grinder
2 wires are not needed to use they are the wires of an supression capacitor on the switch then there are 2 wires from your power cable and 2 that goes to your motor that 4 you only you have to use you can also connect the 2 wires from the s-capacitor with te wires on the motor together thats is how its also correct, (but best is to remove it because its only for suppression for FM ukw radio signals and everybody has DAB+ and the change to have short-circuit is reduced.
7/11/2018 4:43:57 PM • Bench Grinders • Answered on Jul 11, 2018
Needing left hand thread nut for 50-6 duracraft bench grinder Have not been able to find one.
WEN is a leading power tool manufacturer. They produce many kinds of power tools. This grinder is just another quality product from them. WEN 4276 bench grinder has got 2.1 ampere motors that can run in a 3450 RPM without load.
6/7/2018 5:56:37 AM • Bench Grinders • Answered on Jun 07, 2018
2answers
What size of start capacitor?
Double that 100mf
3/12/2018 7:39:31 AM • Bench Grinders • Answered on Mar 12, 2018
What is wrong when bench grinder stalls out when sharping mower blades. Not too much pressure used. Grinder not equipped with a belt
since this is a vague comment, I have to say that some small grinders just do not do well with blade sharpening. I have one that does the same thing when sharpening a blade. It is just too small, horsepower wise, to handle the job.
9/29/2017 2:11:32 AM • Bench Grinders • Answered on Sep 29, 2017
What is motor starting capacitor of GB800 Bench grinder
Hard to find the data The tool is having an centrifugal switch to an breakercontact on the armature on the startup-winding where the capacitor is on , so it should be oft a high capacitance try it to start with 20 mf is maybe high enough to start. you can possible go to less with the capacitance . size compare of the capacity range is difficult because the last years the size differs much and are less
4/19/2017 8:16:18 AM • Bench Grinders • Answered on Apr 19, 2017
I have a Ryobi bench grinder and the grinding belt keeps slipping to one side have tightened to maximum and the belt says its for a Ryobi
it is slipping to one side because the pulley on the end is not aligned correctly on the adjuster arm that holds the front pulley there is a lever or knob that you use to adjust alignment ( instructions in user manual) find that adjustment and slowly move it while the belt is running you will see the belt running position change to you get it properly aligned each belt regardless of ryobi or generic will need adjustment after fitting
11/27/2016 1:44:04 AM • Bench Grinders • Answered on Nov 27, 2016
Bench Factory-Reconditioned Ryobi 2.1 Amp, 6"  Grinder ZRBGH616 Logo
Popular Tags
5 questions posted
Top Bench Grinders Experts
Oliver Street
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Bench Grinder Expert? Answer questions, earn points and help others
View Most Popular
Bench Grinders
  • Bench Grinders
Most Popular Question
get fa3 4 ryobi grinder off
  • Grinders
