20 Most Recent Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Questions & Answers
Operates 5 seconds then burner goes off
Im not sure how to adjust the nozzle pressure, but mine was not getting enough pressure because the air filter had plugged up and had bad fuel lines. I couldn't buy a new air filter so I got a cheapo off brand one from the hardware and cut it to fit. Got good pressure and had no problems since.
3/10/2014 4:10:07 PM • Reddy Heater... • Answered on Mar 10, 2014
My rem50 does not have spark
Check the ignitor circuit. Check also your ignitor spark gap making sure it is not too far or shorted.
2/2/2014 2:13:41 PM • Reddy Heater... • Answered on Feb 02, 2014
2answers
Reddy Heater 60,000 Model R60 only runs with top off.
Sounds lik the vent hole in the filler cap is plugged. Try cleaning it or replace the cap.
1/20/2012 4:23:05 PM • Reddy Heater... • Answered on Jan 20, 2012
2answers
Reddy heater R50B --- plug into 110V , spark
Things I would check in order:
when you plug it in and it "hums" does the fan rotate? if so does the ignitor fire? remove the top cover and look at the fuel nozzle while running, should be an even cone shaped spray pattern. if no spark remove the ignition lead and hold it close to the end of the ignitor, check for spark there, you should be able to slowly pull it farther away fron the ignitor up to about an inch(use insulated pliers) cause if it bites you it stings, if not the ignition module is going bad. if you have a weak fuel spray remove the back plastic cover on the motor and there are filters inside, then remove the six bolts that hold the inside of the filter housing to the motor. inside is your pump, should be a round carbon rotor and four pump vanes. make sure that there is no damage and also check the plastic coupler that the rotor attaches to the motor armature. if everything looks good re-install the pump and filter housing. like in the previous post check the fuel hose and the hose running from the pump to the fuel nozzle for cracks. you need a pressure gauge that is in 1psi. increments and install it in the port on the back of the pump housing that does not have a hole in it. run the heater and check the pressure, it should be around 5psi but the pressure setting should be listed on the side of the heater. to adjust the pressure turn the plug with the hole in it until the pressure setting is correct. as long as everything checks out the problem is usually solved. depending on the model heater there are photocells(flame sensors), high temo sensors, and thermostats that could hinder the function of the heater. these are just some basic troubleshooting steps for forced air kerosene heaters
3/13/2011 4:25:07 AM • Reddy Heater... • Answered on Mar 13, 2011
I have a R60A Reddy heater multi fuel it has two
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
2/20/2011 8:36:36 PM • Reddy Heater... • Answered on Feb 20, 2011
I have a Reddy 60K B.T.U. heater and when I plug
heatman101
2/20/2011 8:32:53 PM • Reddy Heater... • Answered on Feb 20, 2011
Ran out of fuel and
did you put new fuel in and press the reset button located near the plug?
2/13/2011 3:14:06 AM • Reddy Heater... • Answered on Feb 13, 2011
Runs for 10 to 20 mins. than shuts down
Clean the sensor that insures flame is burning.
2/12/2011 4:58:38 AM • Reddy Heater... • Answered on Feb 12, 2011
I have a 55,000 BTU Kerosene heater that will not
The fuel is drawn from the tank by vacuum. If there is any kind of dirt in the fuel or tank, it will clog up that tube and not fire up. Also there is a foam filter at the rear that could be dirty. There is also a reset button by the filter that needs to be reset every time it runs out of fuel.
2/11/2011 6:00:36 AM • Reddy Heater... • Answered on Feb 11, 2011
Plug it in, fan runs for 6 seconds and shuts off.
Could be your fuel,I have to run Kerosene below 32 degrees.Regular diesel gels up and doesn't flow.On the back is a black plastic box with a filter,mine had filled up with carbon.I cleaned it up,put in a new filter and the old girl came back to life.I wish I knew what it was called,it looks like a pump inside.I hope this helped?
2/11/2011 5:54:44 AM • Reddy Heater... • Answered on Feb 11, 2011
Ready Heater 60 wont start.
Check the wires for good connections. If the connections are good, then check the adjustment for the ignitor (sparker or glowplug).
2/11/2011 3:49:45 AM • Reddy Heater... • Answered on Feb 11, 2011
My heater burns for a little bit, then quits for a
heatman101
2/7/2011 4:43:34 AM • Reddy Heater... • Answered on Feb 07, 2011
Heater runs but smells like
Replace the spark plug first. The fuel may also be contaminated. If you can stand the
smoke go for it.
2/3/2011 9:51:44 PM • Reddy Heater... • Answered on Feb 03, 2011
Heater starts, fan runs, injecting
heatman101
1/28/2011 11:03:53 PM • Reddy Heater... • Answered on Jan 28, 2011
Where is the fire eye?
search for the 'fire eye' at the base of the flame.
1/28/2011 11:32:43 AM • Reddy Heater... • Answered on Jan 28, 2011
Heater works fine with the
This is a good indication that your air/fuel mixture is not right...
heatman101
1/27/2011 12:40:06 AM • Reddy Heater... • Answered on Jan 27, 2011
Reddy heater 60
heatman101
1/26/2011 3:22:19 AM • Reddy Heater... • Answered on Jan 26, 2011
My 60,000 btu kerosene heater runs for several
There may be a safety thermal cutout switch that is out of whack.
1/16/2011 9:35:45 PM • Reddy Heater... • Answered on Jan 16, 2011
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
Popular Tags
87 questions posted
Top Reddy Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Reddy Measuring Tools & Sensors
Most Popular Question
operates 5 seconds burner goes off
  • Measuring Tools & Sensors
