20 Most Recent
RTO Outboard Motor Bass Fishing Boat Rod Reel Oil & Grease Questions & Answers
How do i replace a force 120 impellar pump?
Most impellers are in the leg and require the lower oart of the leg to be removed by disconnecting the gear linkage and undoing the bolts that hold the lower half of the leg on, they are just above the water intake.Don't forget the bolt near the prop. Wiggle the leg and slide it down to remove, then place the leg on the bench. The drive shaft protrudes through the impeller housing, remove the bolts that hold the housing on and slide it off. When fitting the new impeller be sure to fold the fins in the correct direction. When re installing the leg be careful to align the cooling pipes correctly.
Cheers, Timo.
Need to now what kind of atv oil go in my honda
4 stroke right. if you plan on keeping your machine for a long time use honda atv or motorcycle oil. ifit is a little thicker than car oil. if you change it often or don't plan to keep it use whatever oil is on sale at the auto parts store. we have a 300ex and a 250ex. we use what is on sale but i change it as soon as it is getting brown.ours are both from 2001 and run graet
Help. recently cavitated my 140 hp 1989 mercury outboard motor
Not really sure what is wrong.Do all the gears work?Does the motor rev properly.Did you change the height of the motor.If the motor etc. are all ok and the motor cavitated at high speed,you may have spun the bush in the propeller hub.The symtoms are,everything works ok but the boat can rev but will have very little forward propulsion.If this is it,the prop needs to come off and taken to be rebushed.The bush stops major damage to the g/box if the prop strikes something.Hope this helps
What is the best fishing rod and reel brand?
St. Croix, Shimano, Shakespeare are popular fishing rod brands and you can choose from these brand without any hesitation. Daiwa, Abu Garcia, Shimano are popular fishing reel brands available in the market. All the product from these brand is durable and high quality and you can purchase from these brands. I have found a pair of an article about the best fishing rods and reels that you can check. Here is the articles:
Best Baitcasting Reels brand
11/30/2022 3:36:23 PM •
Fishing
Answered
on Nov 30, 2022
How do I choose the best fishing reel size for my needs?
Small Spin Reels:
Spinning Reel Size: (1000 or 10)
- Suggested mono: 1-2kg (2-4lb)
- Suggested Braid: 4-8lb
- Common Applications (Guide only): Small fishing reel mostly suited for light fishing in lakes, rivers, bays, harbours etc.
- Popular for fish type (most common species): Bream, Trout, Whiting.
Choosing a fishing rod to go with this size reel: - As the 1000 or 10 sized spinning reel is quite small, a rod you would typically pair this reel to is one with a length of around 6-7 foot that has a fishing line rating of anywhere between 1-4Kg.
Spinning Reel Size: (2000 or 20)
- Suggested mono: 2kg-3kg (4-6lb)
- Suggested Braid: 5-10lb
- Popular for fish type (most common species): Bream, Trout, Whiting, Bass, Flathead, Perch, Luderick.
Choosing a fishing rod to go with this size reel: A 2000 or 20 sized reel being a quite small reel ideally will suit a fishing rod between 6ft - 7ft 6 inches in length that has a line class rating somewhere between 2-5Kg.
Medium Size Spin Reels:
Spinning Reel Size: (4000 or 40)
- Suggested mono: 4kg-6kg (8-12lb)
- Suggested Braid: 8-20lb
- Common Applications (Guide only): Medium fishing reel mostly suited to lakes, rivers, bays, harbours, light offshore boat fishing etc.
- Popular for fish type (most common species): Snapper, Morwong, Tailor, Mangrove Jack, Cod, Bone Fish, Barramundi, Mulloway, Drummer.
Choosing a fishing rod to go with this size reel: A 4000 or 40 reel is where you start to gain a little size so this sized reel will generally suit medium action classes of rods in the 6ft-7ft (barra/snapper style rod) with a line class of around 4Kg-10Kg or in an 8ft-10ft (light surf) rod with a light line class rating of around 3-5Kg. Remember this is a guide only to suggest common applications so by all means you can use this reel for several other applications as well.
11/16/2022 5:20:40 PM •
Fishing
Answered
on Nov 16, 2022
How to buy a fishing reel
Depends on what type of fishing your doing. Out of the two the bait caster is the more challenging to do because you control the line going out. That is good for fishing banks, logged areas, spinner bait. If you just want to cast with bobber go with open or closed reel. Hope that helps.
11/11/2022 1:45:31 PM •
Fishing
Answered
on Nov 11, 2022
