20 Most Recent CEN-TECH Heavy Duty 6/12 Volt Battery Charger/Starter Questions & Answers
2answers
When hooking up the cen-tech 60581 charger/starter
I don't think so, It did that on one of my lawn tractor batteries but not on the other lawn tractor or car battery, I suspect something is wrong with the battery.
4/10/2022 8:33:41 PM • CEN-TECH Heavy... • Answered on Apr 10, 2022
I need battery charger cen-tech 69368 manual
Sorry to say, but Harbor Freight's parts list has no internal parts listed. So to fix it yourself, you may be able to find the little tiny diodes that usually go bad. They don't even have a wiring diagram in the owners manual.
2/5/2016 1:22:21 AM • CEN-TECH Heavy... • Answered on Feb 05, 2016
I would like to see how the swing line 101 Tacker spring assembly goes
not car so moved this to TOOLS (hand) google the user manual or as maker SWINGLINE
1/22/2023 12:58:28 PM • Hand Tools • Answered on Jan 22, 2023
M18 battery one led flashing rapidly when put on charger the charger is solid Greenbush if I put it in my impact the driver light comes on but no action and the batterystill flashes one light..
its not a car so move you to TOOLS (general)most times the battery is now NOGOOD>Milwaukee M18 Cordlessbla bla.never have just one battery or not be able to tell which end is wrong of 3.battery ,charger or tool
9/10/2022 2:45:27 PM • Hand Tools • Answered on Sep 10, 2022
Bostitch hardwood flooring stapler. The Staples misfire. I have to keep pushing on the Staples to make the gun fire properly
take a small brush like one you would use to clean a gun. clean it well and use gun oil to lube it
4/27/2022 7:21:10 PM • Hand Tools • Answered on Apr 27, 2022
5answers
Screws aren’t regular screws. What tool can I use to get them out
Probably torx although we have no idea what your referring to
3/19/2022 10:24:34 PM • Hand Tools • Answered on Mar 19, 2022
I need a zero size phillips bit, and a zero size square drive bit.
For the first, I used "Phillips 0 driver bit" in my Google search. That got several links, including https://www.amazon.com/Phillips-Driver-Long-Miniature-Screws/dp/B07NBP3D7K . The second search was "#0 square driver bit". Amazon had a single bit in stock. Ace Hardware has this 2 pack: https://www.acehardware.com/departments/tools/power-tool-accessories/screwdriver-bits/2160976. Both of these are 1" long 1/4" hex shank for use in any quick-change 1/4" bit holder. I hope this helps. Cindy Wells
2/15/2022 5:24:17 AM • Hand Tools • Answered on Feb 15, 2022
2answers
I need a parts Diagram for a MasterCraft 8.25'' Compound Mitre Saw
I have the manual and prts list , you can phone this number for parts, the parts depot is in Ottawa 613-724-7724. if you the diagram send email to [email protected] and I will send it to you.
11/29/2021 10:06:05 PM • Hand Tools • Answered on Nov 29, 2021
2answers
Online manual for Rapitest Wps 115 Wire/Pipe & Stud Detector
go to the support center for the maunfacture site
8/6/2021 6:18:28 AM • Hand Tools • Answered on Aug 06, 2021
2answers
WHAT STAPLES GO INTO A PRIMO TACKER
Check on the side of the box it will give the size it requires. It will look like this T50, T40, T25, and so on.
3/28/2021 11:20:47 PM • Hand Tools • Answered on Mar 28, 2021
2answers
Is it possible to ask a question about a Gerber multi pliers tool. With having to pay?
They have an online form... but I have had no luck getting mine replaced. I have broke 2 so far.
4/9/2020 7:51:34 PM • Hand Tools • Answered on Apr 09, 2020
My come along (American Power Pull model# 18650) was cranked back way too much and now I can't release the cable using the free spool lever. Any suggestions?
You will get all the information on Toolbox from here https://toolboxwidget.com. Download your PDF copy today or email us to [email protected] for ordering book.
9/20/2019 3:29:29 PM • Hand Tools • Answered on Sep 20, 2019
3answers
Makita Battery Charger DC18 RA
Maybe your battery is died, you can replace it on http://www.drillbattery.com.au/buybattery.php/makita_1220_power+tool+battery.html
3/19/2019 8:25:46 PM • Hand Tools • Answered on Mar 19, 2019
3answers
What is a torx tool?
it is a type of screwdriver bit
1/3/2019 5:10:16 PM • Hand Tools • Answered on Jan 03, 2019
3answers
What are manhole covers made from?
they are typically made out of cast iron, often with little bits of concrete infused in them
10/27/2018 7:14:45 PM • Hand Tools • Answered on Oct 27, 2018
Need to know how to read the roof pitch on my
The pitch of the roof is described as the vertical rise of the roof divided by the horizontal span of the roof. The pitch of the roof is known as slope, and this happens to be a tangent function. When pitches are kept below 3.5, they are considered as low pitch, and when the pitch is kept from 3.5 to 7.5, it is considered as medium pitch anything above than 7.5 is considered to be a steep pitch. Depending on your requirement and style of construction you can decide the pitch of your roof. Click on Gotcha Covered Contracting to know more about roofing.
10/7/2018 4:23:27 AM • Hand Tools • Answered on Oct 07, 2018
Have 'primo tacker' and wish to purchase 10mm long
I have a box of 5000 8mm 960/101 Vanguard Primo Staples - offer me something to cover the postage!
8/29/2018 12:14:24 PM • Hand Tools • Answered on Aug 29, 2018
Black and decker hand prep express model hb5500w wont work
When you are working with brick or concrete, you should check out the Black & Decker DR670 Hammer Drill. It is specifically made to tackle this purpose.
6/7/2018 6:01:53 AM • Hand Tools • Answered on Jun 07, 2018
2answers
Any installation specs on the best way to install
This is just generic instructions just to give you an idea of placement and mounting. I am not sure if your vise turns or not and that would be a big factor also. It depends on where you want it, if anything is close that will interfere with the vise or whatever you have in the vise. Depends how thick the spot is where you want to mount it. If the place is not very thick, use bolt and heavy washer on top of the vise and a heavy washer, a lock washer and nut on bottom. In place of the lock washer and nut, you could use locknut. If the bench where you want to mount is too thick for bolts, use at least 2" lag bolts with heavy washers with the lag bolts as big as the vise holes will accept. You will need the vise as close to the edge without it hanging over the edge of the bench. This is so you will be able to open and close the vise without obstruction. If placement of the vise isn't a big deal, the center edge of the bench would be great although I always mount mine on one end of the bench because of better movement of the part in the vise. Goodluck.
6/3/2018 7:02:53 AM • Hand Tools • Answered on Jun 03, 2018
CEN-TECH Heavy Duty 6/12 Volt Battery Charger/Starter Logo
Popular Tags
7 questions posted
Top CEN-TECH Hand Tools Experts
Ziyaad Khan
Ziyaad Khan
Level 1 Expert
Larry Ng
Larry Ng
john h
Are you a CEN-TECH Hand Tool Expert? Answer questions, earn points and help others
View Most Popular
CEN-TECH Hand Tools
  • CEN-TECH Hand Tools
Most Popular Question
when hooking up cen tech 60581 charger
  • Hand Tools
