20 Most Recent Nosler Ballistic Tip Hunting Bullet Questions & Answers
I have a 308 that I have loaded with 48gr of IMR4831 if I want to be on at 100yds but only have a 50yd range how high would it be at 50yd? 150gr bullet
Site in at 30 yards and you should be dead on. Has to do with the arc of the bullet.
1/2/2018 4:49:28 AM • Nosler Ballistic... • Answered on Jan 02, 2018
Makita DPC 6400 Disc Cutter - blade turns when idling
copy and paste link https://www.manualslib.com/manual/97951/Makita-Dpc-6400-Dpc-6401-Dpc-7300-Dpc-7301.html?page=17
7/1/2023 1:14:25 PM • Cutter Tools • Answered on Jul 01, 2023
My Grinding S350 is not booting ever since I tried the reset button while the batteries are inside and an external 6volts was plugged in by mistake. How to fix this problem , please. Thanks.
Hi, please replace the batteries first. If that does not work, please attempt to factory reset your device ( can reference manual). Thank you.
10/5/2022 7:21:13 PM • Cutter Tools • Answered on Oct 05, 2022
2answers
What is a pipe cutter? What can I use it for?
A pipe cutter is a tool that plumbers use to cut pipes. It gives a much cleaner and better cut than saws.
9/21/2022 7:26:29 AM • Cutter Tools • Answered on Sep 21, 2022
Do I have to wear any protective gear when I use bolt cutters?
You should wear gloves to protect your hands from slips and goggles or face mask to protect your eyes and face from any metal pieces that may come off the bolt you are cutting.
4/20/2021 7:05:06 AM • Cutter Tools • Answered on Apr 20, 2021
CTJ-680 15" Planer instruction manual how do I change cutting knives
Request the manual from the manufacturer/distributor.
1/25/2021 12:47:40 PM • Cutter Tools • Answered on Jan 25, 2021
My 13" General International thickness planer won't turn on. I tried the reset button and still no luck. I replaced the switch and this didn't work. Any suggestions?
With the cheapest multimeters costing as little as just a few dollars there is no reason not to have the ability to check things instead of guessing. With most portable tools and appliances the first thing to check is the power cord because around 60% of the time an internal break is the cause of a tool not starting. Power tools and appliances often have electronics to provide variable speed or soft start. Checking these is beyond the scope of the home repairer but a multimeter can check continuity to any electronic component and from it to the motor and the ensure there is continuity through the motor. If everything else is ok the fault is probably with the electronics if there is any. If you are feeling really brave, the final test is to temporarily and safely bypass the suspected component and apply power.
8/10/2020 3:10:31 PM • Cutter Tools • Answered on Aug 10, 2020
2answers
Can I use a portable bandsaw to cut rebar or do I need something stronger?
you can use a portable bandsaw to cut rebar, I find it to be the best solution when I can't take the rebar somewhere to cut it. But be careful if the metal is heavy it could fall and dent/damage the floor if you're working indoors of cause injury should it land on you.
9/20/2019 1:38:17 PM • Cutter Tools • Answered on Sep 20, 2019
How do I separate 2 utility knifes blades, that are stuck together with oil? Without getting cut myself.
Use a third blade, preferable mounted to your utility handle, to part them. Handle only from the back side and give the utility knife a slight twist as soon as it is between the points of the new blades.
9/13/2019 6:25:00 AM • Cutter Tools • Answered on Sep 13, 2019
2answers
Are bolt cutter blades really sharp?
Manual bolt cutters usually have symmetrical V-edge cutting blades. knife-edge-styles3-uipjjaq4o2dp2d2150uxp5lp-5-5.png With the sharpening angle in the range of 20-30 degrees. 28bc-7-4-_tbi-_head_on_centre_cut_replacement_jaws-uipjjaq4o2dp2d2150uxp5lp-5-9.jpg For comparison, the sharpening angle of the kitchen knife is less than 10 degrees. With such a pretty blunt edge is impossible to cut your finger. But this is the best option for cutting thick metal rods or cables. Like this:bolt-cutter_3-uipjjaq4o2dp2d2150uxp5lp-5-14.pngIf it is interesting to read more information about bolt cutters, I recommend this review - https://toolslaboratory.com/best-bolt-cutter-buyers-guide-2019
7/10/2019 6:57:37 AM • Cutter Tools • Answered on Jul 10, 2019
2answers
Can someone tell me what a pipe cutter looks like?
Take a look at this image of a basic pipecutter; http://www.mccusainc.com/Tools/images/PVC-Pipe-Cutters-1.jpg
6/15/2019 8:13:28 AM • Cutter Tools • Answered on Jun 15, 2019
HOW TO LOAD BLADE INTO HUSKY RETRACTABLE UTILITY KNIFE #1000 032 884
https://www.youtube.com/watch?v=26pv9PAyO1I Helpful video to show how it works. Once you get the hang of it becomes easier.
5/31/2019 4:39:17 AM • Cutter Tools • Answered on May 31, 2019
tip
How to Use a Pipe Cutter?
How to Use a Pipe Cutter? Pipe cutters are really useful tools that can be used in the house to cut pipes that are made from metal or plastic. You could always try using a saw of some kind but pipe cutters will give you a much straighter edge. Here are some basic instructions to help you successfully use a pipe cutter. 1. Decide exactly where on the pipe you would like to make a cut. 2. Loosen the handle on the pipe cutter and place it around the pipe. 3. Now tighten the cutter until the blade is in contact with the pipe. 4. Turn the pipe cutter a few turns around the pipe and it will score a line into the pipe. 5. Keep turning the pipe cutter around until you've cut the pipe off. 6. In order to create a nice straight edge inside the cut pipe you need to take the bottom blade out of the pipe cutter. 7. Place it into the cut end of the pipe and turn it around a few times until it's nice and smooth.
on May 29, 2019 • Cutter Tools
I HAV A PLANER/JOINTER BY MONGOMERY WARD/ POWERKRAFT I NEED KNIVES FOR IT. PLEASE HELP
Have you tried www.ereplacementparts.com
4/24/2019 1:10:00 PM • Cutter Tools • Answered on Apr 24, 2019
I am looking for someone to repair a Einhell water tile cutter in Cape town ZAR
This is an automotive site.
3/19/2019 8:25:51 PM • Cutter Tools • Answered on Mar 19, 2019
Nosler Ballistic Tip Hunting Bullet Logo
2 questions posted
Top Nosler Cutter Tools Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Nosler Cutter Tool Expert? Answer questions, earn points and help others
View Most Popular
Nosler Cutter Tools
  • Nosler Cutter Tools
Most Popular Question
308 loaded 48gr imr4831 want 100yds but
  • Cutter Tools
