20 Most Recent Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Questions & Answers
My baracuda super g + gets stuck on an upstand
2 possible answers. 1 have you put a deflection ring on the cleaner. If not do so 2 you could use a hose motor to pull the cleaner away from the upstand. A hose motor is a cuff that goes on the hose about half way and pulls the hose along. On a long/wide pool you might need 2.
3/31/2019 10:53:15 PM • Zodiac Baracuda... • Answered on Mar 31, 2019
2answers
My leasf cannister submerges causing the G4 to
Move the cannister back in the hose line. (closer to the inlet)
11/25/2018 10:49:36 AM • Zodiac Baracuda... • Answered on Nov 25, 2018
The internal cassette of our
Use locktite on the threads to stop this.
2/22/2017 11:44:50 PM • Zodiac Baracuda... • Answered on Feb 22, 2017
3answers
Moves slowly and the stops. looks like diapham
This seems to indicate insufficient suction from skimmer. Confirm that all other skimmers are closed off properly. Suction can be checked by disconnecting suction hose from pool cleaner and placing your hand over the end of the hose. Suction hose may also have an obstruction which will inhibit proper operation.
12/5/2015 5:44:26 PM • Zodiac Baracuda... • Answered on Dec 05, 2015
2answers
Baracuda stopped working. it is not vibrating but
Could be a small rock or stick stuck in the diaprahm. If you pull the head you can look down both ends, use a ling stick or wire to clear or take the unit apart to find and clear this.
6/4/2015 10:33:45 PM • Zodiac Baracuda... • Answered on Jun 04, 2015
0answers
Diaphragm housing unscreews from the baracuda
is the motor mounted on a dampening plate? do these screws have lock eashers behind them? may need to install these..
1/10/2014 7:31:34 PM • Zodiac Baracuda... • Answered on Jan 10, 2014
Pool vac.
Is it getting enough suction? What type and size of pump is on the pool? If you have Intex or similar those are not strong enough to run a cleaner. Check your filter to make sure it is not clogged. The flow of water through the unit is what holds it to the floor.
7/6/2013 5:19:13 AM • Zodiac Baracuda... • Answered on Jul 06, 2013
My barracuda g4 pool vacuum is running reverse only
That's how they run, they basically just follow their hose!
4/7/2013 12:11:58 AM • Zodiac Baracuda... • Answered on Apr 07, 2013
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
130 questions posted
Top Zodiac Pool & Spa Experts
john h
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Zodiac Pool & Spa
  • Zodiac Pool & Spa
Most Popular Question
g4 barracuda 39 s diaphram assembly
  • Pool & Spa
