20 Most Recent One For All URC-3300 Remote Control Questions & Answers
Comment utilise urc3300b03
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code SearchIf after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
6/20/2019 3:08:59 PM • One For All... • Answered on Jun 20, 2019
What are the programming codes for a dual tv and
Hello
Dremax Frewiew sat box is not listed with One for all URC-3300 codes.
OK.
12/13/2017 11:21:35 AM • One For All... • Answered on Dec 13, 2017
2answers
Need a tv code for Magnavox. Using
Code for Magnavox TV are
0054, 0030, 0179, 1254
Thanx
8/20/2016 10:10:42 AM • One For All... • Answered on Aug 20, 2016
Will this work with receiver sw375
What? Banana?
9/16/2015 1:00:34 PM • One For All... • Answered on Sep 16, 2015
I need code for Alba Digital Set Top Box STB102
0028,0021. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
1/23/2015 7:44:14 AM • One For All... • Answered on Jan 23, 2015
0answers
PLEASE I NEED regservo serial?
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box. http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
5/30/2014 5:50:18 AM • One For All... • Answered on May 30, 2014
I have a one for
needs the codes for a one for all big esay remote urc-3300b03
an emerson tv
5/9/2014 10:43:51 PM • One For All... • Answered on May 09, 2014
0answers
Como programar un control satelital DISH NETWORK para que funcione con television magnavox
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
3/1/2014 1:03:12 PM • One For All... • Answered on Mar 01, 2014
I need code for tv sharp
0286,0288,0280,0284. Try these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/
2/26/2014 9:31:50 AM • One For All... • Answered on Feb 26, 2014
I need code for tv sanyo
0038,0031. Try these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/
2/26/2014 9:31:10 AM • One For All... • Answered on Feb 26, 2014
I need code for tv Magnavox
0281,0288,0285,0280. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
2/25/2014 4:24:05 AM • One For All... • Answered on Feb 25, 2014
0answers
Code philco converter remote
0019,0011. Try these codes. If you wish to get more; check the sites linked here. Both the sites have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/
2/1/2014 4:19:58 PM • One For All... • Answered on Feb 01, 2014
Need code for urc-3300im to a sanyo tv
0381,0389,0385. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
12/4/2013 12:42:23 PM • One For All... • Answered on Dec 04, 2013
0answers
Urc 3064b00
Be the first to answer 11/3/2013 5:46:12 AM • One For All... • Posted on Nov 03, 2013Be the first to answer
One For All URC-3300 Remote Control Logo
220 questions posted
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • One For All Televison & Video
Most Popular Question
adjusta magic control englander bed will
  • Televison & Video
