20 Most Recent Bosch SHU9915UC Dishwasher Questions & Answers
Bosch shu9915uc dishwasher when turned
Welcome to FixYa.
Based on your description "dishwasher when turned on sounds like drain pump is running but water will not enter dishwasher" , it sounds like the emergency overfill switch has been actuated. Here`s what to do and what to look for.
**Turn off the breaker/power at your homes service panel...safety first of course**
Remove the the bottom panel, referred to as a toe panel or kick-plate, essentially the lower service panel shown here...
When you remove the outer toe panel, there will be another small panel which is non finished steel, I find removing that allows much easier access as well.
This panel can be somewhat more difficult as it secures the plastic channeling for the wires but if you observe closely you`ll see it does "snap" out of place...carefully.
Once the panel has been removed check for any obvious signs of water in the base ( the unit has a plastic overfill basin with a float which will actuate an emergency overfill cycle, hence the drain pump runs & runs )
If you don`t see any water in this area, direct your attention to the left in this basin/bottom ( from the front to be sure ) and you should see a device which will resemble a "stir stick" you`d use for coffee etc. it will be a red in color stick.
With the aid of a wooden spoon, long screwdriver, or if you can manage to reach by hand, lift it up and down gently and listen for a "click".
If there is no sign of water and you can here the "click" when lifting up and down the float actuater ( red stick ) then turn the machine back on and give it a try before reassembling the toe panel so you can observe for any possible leaks.
Let me know what you find. This is the most likely cause of the symptom you are describing so we can move forward if this doesn`t resolve the issue.
Thanks for choosing FixYa. Good luck.
Regards,
Macmarkus :)
1/5/2022 5:00:30 PM • Bosch SHU9915UC... • Answered on Jan 05, 2022
The upper spray arm came detached, how do I reattach it?
On my dishwasher, this arm attaches with a huge gray plastic screw. If it comes loose, you'll usually find the spray arm sitting in the bottom rack, but the screw falls down to the bottom of the tub. The spray arm has a hole that goes all the way through its center. One of these holes is larger than the other, so the arm will only attach in one direction. Most of the spray holes on the arm face "up" when installed. Slide out the upper rack, position the spray arm on its pivot, then insert the screw and turn clockwise to tighten it. The arm should spin freely. If this arm isn't attached, none of the dishes will wash well (due to a loss of water pressure).
9/9/2021 12:26:09 PM • Bosch SHU9915UC... • Answered on Sep 09, 2021
Bosch dishwasher has high pitched squealing noise
A high-pitched sound which occurs when filling is usually cavitation - air in the water valve causes a kind of "squeal". It's relatively harmless, but can be annoying. You may need a new inlet valve. But first just try detaching and re-attaching the hoses to the valve. Sometimes that's enough to fix it.
6/11/2021 11:56:04 PM • Bosch SHU9915UC... • Answered on Jun 11, 2021
2answers
Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
10/15/2019 1:17:54 PM • Bosch SHU9915UC... • Answered on Oct 15, 2019
2answers
Bosh wishwasherhow do you unlock the child safety lock?
Hello there and welcome to fixya The child lock function of your Bosch dishwasher prevents accidental program changes and stops children playing with the controls while the appliance is running. You might want to turn the lock off if it has been accidentally turned on. The controls of the dishwasher are disabled, preventing you from starting a new wash, while the child lock is running. The lock is simple to turn on and off, as necessary, in just a few secondsRead more: How to Get the Child Lock off a Bosch Dishwasher ' eHow.com http://www.ehow.com/how_12069321_child-lock-off-bosch-dishwasher.html#ixzz2E7bFXnhsplease feel free to give me a rating if this works for you it helps me give you the best help i possiabley can ok Best regards Mike
7/25/2019 4:51:00 AM • Bosch SHU9915UC... • Answered on Jul 25, 2019
"Runs" even with door open - water drains
Unplug the dishwasher from the plug site, wait one minute and plug it back in. The computer will reset itself. It should run perfectly.
10/28/2017 9:11:18 PM • Bosch SHU9915UC... • Answered on Oct 28, 2017
My Bosch Classixx (about 10 years old) dishwasher
Check you dont have a small inline filter inside the inlet water pipe. Either at the "tap" end or can be on the machine itself. They look like a small sieve. Remove it and clean with a toothbrush. Then put back.
4/7/2017 3:02:31 AM • Bosch SHU9915UC... • Answered on Apr 07, 2017
I think the rinse cycle is not working on my Bosh
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
9/17/2014 10:23:41 PM • Bosch SHU9915UC... • Answered on Sep 17, 2014
Bosch SHU9915UC Dishwasher Logo
212 questions posted
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
bosch dishwasher will not stop running
  • Dishwashers
