20 Most Recent
Bosch Classixx WFO 2866 Front Load Washer Questions & Answers
Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
All the lights are flashing and nothing happening.
If all the lights are flashing it is without a doubt a faulty main board. If only certain lights are flashing it is showing an error code. Tell me which lights are flashing and will point you in the right direction.
Approximately will cost 100 to 140 for a board, which also has to be programmed
Reset pcb bosch classixx 1200 express
There is no reset as such, if the motor shorted when the motor brushes went there is a good chance that it blew the motor tracking or relay on the board. Sometime this is indicated by F20 or F21. Unfortunately this will be a new board. You could try to run a motor test as follows:Hold in the start button while turning the dial one click to the left (30 easycare) wait until the display shows 888 or two indicators light up next to dial.Release start and turn dial to 60 cotton (WITHOUT GOING THRO THE OFF).Press startThis should start a motor testslow turn one way, slow turn the other, pump on then up to full spin.(some machines will show the rpm on the display).If this does not work, you probably need to change the module aswell.Best of luck
