20 Most Recent Bosch WFE 2021 Front Load All-in-One Washer / Dryer Questions & Answers
What capacity Bosch WFE2021 washing machine
Traces of dark lines on the washer are caused by defective bearings and seals. they need to be changed.
3/17/2019 11:09:15 AM • Bosch WFE 2021... • Answered on Mar 17, 2019
0answers
Wfe2021
Be the first to answer 2/10/2014 9:31:30 AM • Bosch WFE 2021... • Posted on Feb 10, 2014Be the first to answer
0answers
My bosh washer wfe 2021 is showing an error code 1
Hi
The issue is with the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
10/3/2011 1:18:24 PM • Bosch WFE 2021... • Answered on Oct 03, 2011
2answers
Bosch Washing Machine WFE 2021
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
5/19/2011 1:35:20 PM • Bosch WFE 2021... • Answered on May 19, 2011
Hello! How can I get the instructions manual for
You're in luck -
http://www.bosch-home.co.uk/
click on "download product manuals"
click on "click here to download product manuals" - this will open a new tab or window.
Enter WFE2021EE/01 and click on Go.
results are in spanish, but I expect you'll be ok with that.
1/11/2010 6:23:37 PM • Bosch WFE 2021... • Answered on Jan 11, 2010
Flickering display panel Boschwfe 2021
It may be the door interlock that is faulty. This is the cheaper solution however it maybe the the electonic board. In any case it needs the attention of a bosch Technician. Cross your fingers its the door interlock.
0417362396 Melbourne metro Area
Regards Sam
9/20/2009 1:38:24 AM • Bosch WFE 2021... • Answered on Sep 20, 2009
2answers
Bosch WFE 2021
I suggest that you check the brushes in the motor for wear.
Remove rear panel, remove drive belt, undo bolts securing motor, unplug motor lead and earth wire.
Lever motor back, keeping hold of it, and remove.
Check the brushes, they are at the opp end to the motor pulley, if there is less than 8mm left, then replace brushes.
I would also check the pump filter, and clean if req'd.
Please rate my fixya solution.
Thanks.
8/24/2009 8:46:34 PM • Bosch WFE 2021... • Answered on Aug 24, 2009
2answers
Bosch WFE 2021 machine does not complete wash...
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
2/5/2009 6:30:44 PM • Bosch WFE 2021... • Answered on Feb 05, 2009
3answers
BOSCH washing Machine WFE 2021
perhaps it is waiting for user to add fabric softener? how it got in this mode?
7/29/2008 8:27:48 AM • Bosch WFE 2021... • Answered on Jul 29, 2008
Bosch wfk2201 washing machine
Contact Bosch through their web site. They offer solutions to some problems if yours is no listed send them an email.
2/12/2008 1:25:42 PM • Bosch WFE 2021... • Answered on Feb 12, 2008
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
1/18/2008 7:52:08 PM • Bosch WFE 2021... • Answered on Jan 18, 2008
Bosch Vision washer door seal replacement
You will need the numerical model number.
Bosch - Door Boot Seal 00701333 - Appliance Parts
PartSelect.ca https://www.partselect.ca > PS8735900-Bosch-0070133... Nov 10, 2021 - Door Boot Seal ; This part fixes the following symptoms: Leaking ; This part works with the following products: Washer. ; This part works with the ... Rating: 5 · ‎ 1 review
00667487 Bosch Washer Door Boot Gasket
Reliable Parts https://www.reliableparts.ca > ... > Bosch Dishwasher Parts Door boot gasket works with some Bosch, Thermador, and Gaggenau models of washing machines. This is a genuine OEM part that works for some models of Bosch, ... $101.27 · ‎ In stock
Shop Bosch Washing Machine Gasket & Seal Parts
Repair Clinic https://www.repairclinic.com > Shop-For-Parts > Bosch-... Find Bosch Washing Machine Gasket & Seal Replacement Parts at RepairClinic.com. Repair for less! Fast, same day shipping. 365 day right part ..
4/15/2024 7:31:48 PM • Bosch Washing... • Answered on Apr 15, 2024
Bosch 100 Nexxt washer won't spin. Filter cleaned of debris, belt replaced. Drum can't be spun by hand, drags and seems misaligned after unbalanced load with noise coming from drum.
That sounds like the bearings have collapsed. Time to call a domestic appliance engineer or look for a new machine.
4/10/2024 6:18:33 AM • Bosch Washing... • Answered on Apr 10, 2024
Bosch lr30 receiver not turning on
Potential causes and fixes: Battery Terminal Corrosion: Cause: If your Bosch laser receiver has been submerged in water, the battery contacts and sometimes the circuit board may have corroded. Fix: Remove the batteries and clean the battery terminal contacts. Pry open the bottom cover and clean any corrosion on the circuit board. Calibration Issues (for Bosch GLL 2-20): Cause: Dropping the Bosch GLL 2-20 can lead to misalignment and errors. Fix: The best way to address this problem is to calibrate the laser level. You can either contact the Bosch service center or follow the calibration instructions in the manual. General steps for calibrating a laser level with a misaligned pendulum: Remove the screws and outer cover. Locate the pendulum hanging in its stationary position. Remove the glass window of the laser level. Adjust the stationary position of the hanging pendulum using the main adjustment screw. Fine-tune right-left adjustments using other smaller adjustment screws. Reassemble the laser level. Cracked Glass Lens (for Bosch GLL 2-50): Cause: If the horizontal glass lens is cracked, it affects accuracy and safety. Fix: Unfortunately, this problem is often unrepairable. It's advisable to replace the laser level to ensure safe operation1. Remember to lock your laser level when not in use or during transportation to prevent pendulum movement1. If these steps don't resolve the issue, consider reaching out to Bosch for professional assistance or repair
4/7/2024 11:28:06 AM • Bosch Washing... • Answered on Apr 07, 2024
Bosch WFE 2021 Front Load All-in-One Washer / Dryer Logo
31 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
get instructions manual
  • Washing Machines
