20 Most Recent
Buck Scrubbing Bubbles& Automatic Shower Cleaner - 2 Pack Questions & Answers
Scrubbing Bubbles Automatic Shower Cleaner quit working
I just experienced the same problem for the third time. Call J&J Customer Care 1-800-558-5252. Select option 3.
Explain your problem and they will send you a coupon for a new Scrubbing Bubbles Starter Kit with a full bottle of solution in 7 to 10 business days. I would not waste my time to take the old apart, just call and get a NEW ONE.
Jim Jones
[email protected]
I have three of your
We are not makers of the products you indicated. Below is the contact information for Johnson and Johnson.
Johnson and Johnson consumer product helpline will be happy to help you with questions or comments
about our U.S. and Canadian consumer products.
Phone:
1-800-494-4855 (U.S.) 1-877-506-7352 (Canada)
Write:
SC Johnson
1525 Howe Street
Racine, WI 53403
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue:
Manually Clearing an Airlock:
Run the jets on low for about 30 seconds.
Then run the jets on high for another 30 seconds.
Repeat this process 3 or 4 times.
If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out.
If this doesn't work after several attempts, try a different approach.
Bleeder Valves or Pump Method:
Some spas have bleeder valves that allow you to bleed air out of the lines.
First, turn off the spa at the breaker.
Access the pump and loosen the valve to allow the air to escape.
When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve.
Run the pump to ensure the jets are now pumping water as expected.
Why Are the Jets Not Working on One Side Only?:
Many hot tubs have two water pumps.
If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps.
It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself.
Can You Use a Spa with an Airlock?:
It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM •
Home
Answered
on Apr 03, 2024
