20 Most Recent
Makita 2704 Contractors 15 Amp 10 Inch Benchtop Table Saw Questions & Answers
My 2704 is blowing fuses, there is no fault on the
You may have a motor winding lead that has touched the case of the motor, shorting out the windings, drawing too much amperage, thus blowing fuses. You may have to disassemble your motor and check the stator windings for a short as well as the armature windings. Also the motor could be hanging up due to bearing trouble and causing the motor to draw too much amperage. Probably the cheapest thing to do would be to replace the motor.
My 2704 bench saw has
before you replace it, you can try and clean the commutator. To do this first unplug the tool and turn the saw on its backside. remove the brushes and find a emory board (cardboard) while turning the blade by hand (use a glove) lightly touch the board to the commutator to try and clean the surface, While doing this try and notice any raised sections of the comm, if there are any then you would need a new armature and possibly field. I would try cleaning first though. Let me know if you have any more questions.
My makita 2704 table saw
there are no capacitators that I see. What I would do is unplug the tool and remove the brushes and check there condition for burning/wear and if you can look into the brush tube and carefully turn the motor by hand and look at the commutator for discoloration. Let me know if you need more help. You can download a breakdown at "makitausa.com"
Electric brake doesnt work unless
sounds like a faulty switch. before removing write yourself or take a photo of where the wires go. Also check the condition of the brushes, if they are too short the brake won't work either.
Makita 2704 I overloaded my motor
if the motor RPM drops dramatically when the noise starts, it is probably a dry motor bushing, if this just started, lubricating the motor may just fix it.
I have a makita 2703
First thing I would check are the Carbon Brushes. The are # 75 in the picture
Hope this answers all your questionsPlease remember to Rate/vote for any solution that helps you out.Thanks for using Fixya.
10/12/2022 4:35:39 AM •
Makita Saws
Answered
on Oct 12, 2022
