20 Most Recent Sharp Aquos 32 inch LC-32LE340M LED Multisystem TV FOR 110-220 VOLTS Questions & Answers
tip
Sharp LED bilking
Remove Main's plug Press Volume down & Input button from LED panel and switch on LED.
2) "K" will appear on screen left side top.
3) Press Channel Down & Volume down from LED panel
4) Adjustment page will display. 1/10
5) Go to 9/10 by pressing Up & Down button from remote
6) Select EEP - and press ok button.
7) Switch off and Switch on LED.
How to fix sharp aquos no picture no sound just blinking red indicator
1/13/2016 11:50:53 AM • Sharp Aquos 32... • Answered on Jan 13, 2016
Tv is dead means power supply board is ok but whn
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/22/2013 4:03:16 AM • Sharp Aquos 32... • Answered on Oct 22, 2013
Cannot power on
The problem you've posted here haven't enough details to provide a solution. Give more details please. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
4/14/2013 3:56:03 PM • Sharp Aquos 32... • Answered on Apr 14, 2013
2answers
SHARP AQUOS LC-60E78UN 60 inch LCD TV. Are there any firmware updates please?
Question edited for a lot more clarity! All questions need full 'make model (what it is)' please.Question moved to Sharp Aquos category.This is their support page which is pretty bad. There is an email link. You don't say WHY you want a firmware update, but firmware in not supplied for televisions according to our Fixya television expert Larry. Firmware updating is fraught with danger and should not be undertaken lightly even when it is available. Sharp only supply software updates, no firmware.https://www.sharpusa.com/Support/ProductDetail.aspx?model=LC-60E78UNSOFTWARE updates are here in the manual on this page and continues in detail on the next page.https://www.manualslib.com/manual/318507/Sharp-Aquos-Lc-60e78un.html?page=24..
11/25/2023 11:10:39 PM • Sharp Aquos... • Answered on Nov 25, 2023
2answers
Hi. I have a logo banner on the top left of my screen I can't figure out how to remove.
Go to Menu select function or Service and checked auto demo is on. If it is on make it OFF
11/11/2022 10:37:31 PM • Sharp Aquos... • Answered on Nov 11, 2022
2answers
Sharp TV LC60LE745U the screen remained black and an arrow on the bottom of the TV stay blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
10/8/2022 10:22:49 AM • Sharp Aquos... • Answered on Oct 08, 2022
Can I transfer the data stored in my TV to my USB?
No, you just told the television to format the USB into its own formatting format. It doesn't back it up for you. You should have purposely made a back up of everything on the USB memory stick to your computer. If you haven't done that, you can put the USB stick into the computer and use 'Undelete' software. Recuva is pretty good and the ones that normally say 'Free', mean they are free to see what is can find, but not to restore is back. https://www.google.com/search?q=%27Undelete%27+software Recuva https://www.ccleaner.com/recuva Everyone should have CCleaner! ..
3/12/2022 7:57:21 PM • Sharp Aquos... • Answered on Mar 12, 2022
Program a sharp aquos remote to control a samsung bluray dvd player
Not sure you can
12/22/2021 5:58:07 PM • Sharp Aquos... • Answered on Dec 22, 2021
Scanned Channels not saving on my Sharp AQUOS 32 LE185M LED TV.
https://elektrotanya.com/cgi-bin/download2.cgi?dk=wgzgtxz9xfakb6w5s2gbjalr7l6hmh579r0th7lfiongeyjc&fid=105643&file=sharp_aquos_lc32_40_46_52le700un.pdf Should be the faulty memory IC. Download its service manual by the above link, and refer it. If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
10/16/2021 6:51:04 AM • Sharp Aquos... • Answered on Oct 16, 2021
Sharp Aquos LC-52D62U Liquid Crystal Display; Power LED blinks at a constant rate. TV does not come on.
This model was known for bad capacitors in the power board, have you tested them and or power supply voltages?
8/20/2021 12:01:51 AM • Sharp Aquos... • Answered on Aug 20, 2021
2answers
How can I fix my Sharp Aquos TV screen that turn red
One way to deal with this issue is to power cycle your Sharp TV. This way you will be able to find out if the light blinking is due to improper bootup and hopefully resolve it. https://downloadnox.onl/ https://vidmate.vet/ https://vlc.onl/
8/17/2021 11:38:19 AM • Sharp Aquos... • Answered on Aug 17, 2021
Where or is the volume button on my Sharp Aquos tv? I ordered a remote but it won't be here till Sat. Thank you for accepting me on here :
What is the model number of that TV. without it, how can one respond? If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/
7/17/2021 11:59:25 AM • Sharp Aquos... • Answered on Jul 17, 2021
My sharp aquos LC-60LE644U works for 10-15 minutes off antenna
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. . Pull up older posts. http://electronicshelponline.blogspot.com/ . https://elektrotricks.blogspot.com/ http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site by type in the brand name of your TV, at its search box at the right column. View the sites by desktop computer or by Webview by mobile. Mobile view has no search box.
7/11/2021 1:34:53 PM • Sharp Aquos... • Answered on Jul 11, 2021
Sharp Aquos 32 inch LC-32LE340M LED Multisystem TV FOR 110-220 VOLTS Logo
7 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
tv dead means power supply board ok but
  • Televison & Video
