20 Most Recent Breville WC15XL Compact Wine Cooler Questions & Answers
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Breville WC15XL... | Answered on Apr 10, 2009
Please check if this is the model you have and maybe this can help. good luck. d066f00e-d454-4535-8840-331d35e2a9ef.pdf
Breville... | Answered on May 09, 2017
I'm not exactly sure what you mean by a washing machine hookup. Most washing machines hookups have two hose bibbs (faucets that a hose can screw on to), one for hot and one for cold. Refrigerators have a 1/4 inch flexible line, either copper or plastic. So, I'm assuming that you mean you have a hose bibb for the water supply and you want to connect it to the quarter inch line on the fridge.
The best approach would be to remove the hose bibb and connect to the line that is feeding it. Assuming that it is a 1/2" rigid copper pipe you can get adaptors at a plumbing store or at a store like Home Depot to step it down to 1/4", then connect to the fridge line with a compression fitting. If your hose bibb is threaded, you would start at the wall with the same size threaded connection and see what your local store has available in the line of adaptors. Best would be if you can find a single adaptor that will go from 1/2" to 1/4". You may need one to go from 1/2" to 3/8" and another to go from 3/8" to 1/4".
A second approach that would be a jury rig type of thing (say if you can't get the hose bibb off) would be to get a hose end connector to attach to the faucet and step it down with clamps and tubing. Use adaptors that fit inside tubing of successively smaller sizes (2 steps will probably do it) ending with 1/4" plastic that you can attach to your fridge with a compression union. (they make 3/8" to 1/4" compression unions, so you would only need to end with a 3/8 inch tube making the connection with the adaptor/union.
Modify this according to what you have in the house (say if you have 5/8" water lines instead of 1/2").
If I'm not understanding your problem correctly, please clarify.
Breville... | Answered on Aug 03, 2009
Thank you for adding information to your question.
Page 34 of the manual gives phone numbers in South Africa to call for assistance. I did not see the error message code 6 online anywhere I searched.
https://www.defy.co.za/wp-content/uploads/2016/06/SBS-F740-F790-Eco-Refrigerators-Manual.pdf
Refrigerators | Answered 3 hours ago
Defrost drain clogged
Refrigerators | Answered Yesterday
There is a defrost drain under evaporator coils in freezer section that is most likely clogged. Back inside freezer panel will have to be removed to access it.
WE HAVE NO CLUE NOR DO WE CARE CHECK WITH THE MAKER OR LOCAL RETAILER .
each maker has their own technique. Google
make model change water filter
Then look at the video tab.
Refrigerators | Answered 2 days ago
Breville WC15XL Compact Wine Cooler Logo
11 questions posted
Top Breville Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Breville Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Breville Refrigerators
Most Popular Question
use breville wc15xl wine chiller
  • Refrigerators
