20 Most Recent Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Questions & Answers
2answers
Cannot tighten blade on old craftsman circular
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
5/2/2022 4:54:54 PM • Sears Craftsman... • Answered on May 02, 2022
2answers
I need the owners manual for a Craftsman circular
Craftsman owner's manuals are available from www.ManageMyHome.com. You'll have to register with this Sears site to download, but they are otherwise free of charge.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
3/31/2021 10:38:50 PM • Sears Craftsman... • Answered on Mar 31, 2021
2answers
Cannot remove blade from craftsman circular saw
without knowing the model number I can only assume that it is a circular saw and the blade is on the right hand side and then the bolt should be a standard thread. Hold the spindle lock in and turn the bolt counter clockwise to loosen. If other than it would probably be a left hand thread and do just the opposite. Let me know and if so please provide the model number so I can look at a breakdown for the tool.
3/31/2021 10:37:51 PM • Sears Craftsman... • Answered on Mar 31, 2021
2answers
Instruction manual
Close match to 315.108220 Craftsman Circular Saw Owners Manual is the 315.108241 PDF manual The 315.108241 manual is available for free download at: http://www.hammerwall.com/Manuals/Craftsman/Description/315.108241/Craftsman%207%2014%20in.%20Corded%20Circular%20Saw/L0807084/
3/31/2021 10:28:23 PM • Sears Craftsman... • Answered on Mar 31, 2021
Where is the reset button on a craftsman circular
The Craftsman saws have no reset (I thought the same for my own saw). If you have the original operating manual (or can get the manual at Sears Parts Online), you can check the two carbon brushes. I posted a tip for my model but it may apply for any Craftsman circular saw. Locate and remove the rear motor cover, then look for the two brushes. Insert a wood or plastic probe (such as a toothpick) between the brush and the rotor contact, then try to push the brush away from the rotor. If it doesn't move or it does move but stays stuck, the brush has to be physically moved to release it and allow it to spring back. You must check both brushes. Get help if you cannot do it yourself, as the brush removal is simple but delicate. And this will save you from buying a new saw.
3/31/2021 10:23:03 PM • Sears Craftsman... • Answered on Mar 31, 2021
2answers
My saws light and laser
i would test the switch with a meter and replace if needed
3/31/2021 10:16:27 PM • Sears Craftsman... • Answered on Mar 31, 2021
Craftsman radial saw runs (hums) but wont turn over
The motor capacitor is dead. Replace it and it'll be right as rain!
Regards, --W/D--
2/19/2018 3:27:31 AM • Sears Craftsman... • Answered on Feb 19, 2018
Got a Craftsman 5 1/2 in circular saw that just
worn or damaged bearing --brushes worn --
7/25/2017 9:42:16 PM • Sears Craftsman... • Answered on Jul 25, 2017
2answers
Need substitute switch part for sears saw
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
10/16/2016 2:08:10 PM • Sears Craftsman... • Answered on Oct 16, 2016
Where is the blade lock for CRAFTSMAN 315.10951
I've had this same circular saw since new (the 80's). There is not a spindle lock. The bolt turns clock-wise to tighten. I usually hold the blade with a gloved hand and snug up the bolt. It will tighten when in use. When removing the blade, one can place a block of wood between two teeth to lock it in place.
3/26/2016 10:33:13 PM • Sears Craftsman... • Answered on Mar 26, 2016
My circular saw is not working now. Help me what to do.
broken contact powercable , switch but measure to carbonbrushes to each other with signal measure multimeter , the autostop in the carbonbrush can be activated. or 1 of the 4 wires on the electricfield is broken
2/25/2016 12:50:09 PM • Sears Craftsman... • Answered on Feb 25, 2016
Blade screw keeps turning when trying to replace blade
remove the power lead from the wall socket put a screw driver in the teeth of the blade and use it as a stop against the guide use the right size spanner and undo the blade retainer nut
9/6/2015 7:31:45 AM • Sears Craftsman... • Answered on Sep 06, 2015
0answers
Which direction are the blades turning
Always away from you.
7/18/2014 2:47:35 PM • Sears Craftsman... • Answered on Jul 18, 2014
2answers
I cannot get my Craftsman 7-1/4 in. Circular Saw
Release the base plate lock so the saw will sink into the well at the bottom of the case.
9/5/2013 11:14:55 PM • Sears Craftsman... • Answered on Sep 05, 2013
0answers
2answers
Craftsman 7.5in. circular saw model #31511880.
Is this a brushless motor?
5/21/2013 4:01:13 AM • Sears Craftsman... • Answered on May 21, 2013
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
77 questions posted
Top Sears Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sears Saw Expert? Answer questions, earn points and help others
View Most Popular
Sears Saws
  • Sears Saws
Most Popular Question
craftsman radial saw runs hums but wont
  • Saws
