20 Most Recent
RTO PasLode 900420 Impulse Framing Nailer Questions & Answers
Problem with battery connection
if you remove the battery and look into where the battery goes at the bottom you will see the two prongs that make contact with the battery pack gently pry away from the side not to far but just a bit if you can not insert battery when done you pried to, far just bend them back until all works properly
Nail gun wont fire nails
you need to give more info mate , it the battery charged , is there gas in it how old ,is it filthy inside etc etc
I changed the gas cylinder in my paslode framing
Make sure you have the correct gas cylinder. There are more than one type of cylinders for these nailers. If it is not correct it won't seat and gas will leak. Whiring sound is normal, fan mixing oxygen. Make sure "O" ring is in place under the gas cylinder.
Passlode 900420:
you have a dead short in fan. did you have fan apart for cleaning unit? If so take back apart and check for bare wires grounding the fan. curcuit is not completed
Paslode IM250A 900600 fan runs all the time. Gun
You have a stuck head switch - it is part of a circuit assembly (#89), it may be the actuator (#66) causing it.
https://www.toolpartsdirect.com/paslode-90060-cordless-16-gauge-angled-finish-nailer.html
Paslode finish nailer fan motor
If you send the model number I can give you a specific part number, but the issue is the head switch is stuck on.
This can be caused by a bad switch or the cylinder not returning entirely.
Paslode 900420 nailer fan keeps running
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
Paslode nail gun will not fire
Make sure the spark plug ignites. Take tool apart as in cleaning. Hold micr switch near fan and watch as you pull trigger. you will see a spark. If not check the lead to igniter
No spark, is there a way to test spark box?
Not really, you can check the spark unit by taking the cylinder assembly off as a unit and you will find a lever at the top, put a battery in tool and depress this lever, the fan should run for a few seconds and then shut off, next depress the trigger and the same should happen. Then while holding the lever (watch fingers on fan) depress the trigger and you should get spark, if not I would look for a loose spark plug wire at the spark unit, check for the wires grounding on the head assembly and broken wires there also. Also when checking at the spark unit make sure one of the 2 plugs is not partially pulled up. The simplest thing to replace is the circuit assembly, but if you have it apart it would be worthwhile to take it to a shop and see if they can change one part or the other to ensure you get the right one first. Hope this helps.
