20 Most Recent DeLonghi DN 125 Dehumidifier Questions & Answers
The dehumidifier is no longer
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
7/13/2011 4:10:19 AM • DeLonghi DN 125... • Answered on Jul 13, 2011
Need an Operation Manual for
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
6/1/2011 12:17:46 PM • DeLonghi DN 125... • Answered on Jun 01, 2011
My delonghi dem 10 dehumidifier is working and collecting water but but the pause is continuously flashing why is this
The flashing pause light on your DeLonghi dehumidifier indicates that the unit is in a defrost cycle. During this time, the compressor shuts off and the fan continues to run in order to thaw any ice that may have formed on the coils. This process typically lasts for 10-15 minutes before the unit resumes normal operation. If the pause light continues to flash even after the defrost cycle is complete, it may indicate a problem with the unit's sensor or control board. In this case, it is recommended to consult the user manual or contact a professional for assistance with troubleshooting and repairs.
2/26/2023 2:11:51 PM • DeLonghi... • Answered on Feb 26, 2023
I have a DeLonghi NF 90 air conditioner/dehumidifier. The dehumidifier does not appear to be working - first time I have tried to dehumidify. Have had this unit for about 8 years. Thanks, Niall
If the air conditioner works and is blowing out super chilled air, then the dehumidifier function should work. The function takes in warm moist air and passes it over plates which are marginally colder than the ambient air. The air condenses and drips into a collection tank, or some have drain hose for putting into a floor drain. After 8 years, it may need service and gassing up, but you may also have drier air than you think. Whether is works in AC Mode is the key.
6/16/2022 3:44:34 PM • DeLonghi... • Answered on Jun 16, 2022
Delonghi dehumidifier DE500 P leaking water
The hose is supposed to be in the tank. Someone emptied the tank and forgot to put the hose back.
9/16/2021 4:36:12 AM • DeLonghi... • Answered on Sep 16, 2021
Where can I buy the filter for DeLonghi DN 125 R Dehumidifier
Apparently NOWHERE! Contact DeLonghi direct https://www.delonghi.com/en-int/products/comfort/air-treatment/dehumidifiers This search query should have shown lots of places, Maker direct, Amazon, eBay and Appliance parts suppliers like Part Select dot com. It's very odd. https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00f9Jx3klLUl0dKNUo5ffEHVuQLMA%3A1612057058213&ei=4gkWYNW0DJWq1QGmg6TQAg&q=DeLonghi+DN+125+R+Dehumidifier+replacement+filter ..
1/31/2021 1:43:26 AM • DeLonghi... • Answered on Jan 31, 2021
Can a Delonghi dehumidifier DH25 be connected to an outlet pipe to get rid of the water? It's working fine, but I ned to empty it nearly every day
Some dehumidifiers have provisions for connection of an ordinary garden hose to drain into a tub, a standpipe, or a sump pit.
12/28/2020 2:12:45 PM • DeLonghi... • Answered on Dec 28, 2020
2answers
DELONGHI DH300P E3
The E3 Code, indicates that the air intake filter needs to be removed and cleaned. Be sure the unit is OFF and unplugged before removing the filter. Filter cleaning should be performed at least once every two weeks, as part of Routine Maintenance.
6/6/2020 6:44:27 PM • DeLonghi... • Answered on Jun 06, 2020
I would like to have the delonghi de400p drain from front hose instead of into bucket
all this info is in the manual. Either you threw it away or are a person who does not like to read.
10/28/2019 6:40:58 PM • DeLonghi... • Answered on Oct 28, 2019
2answers
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
5/16/2019 10:55:04 AM • DeLonghi... • Answered on May 16, 2019
De longhi dehumidifier showing yellow light
Usually happens when the float valve is stuck in the down or up position try wiggling the handle to release or if the collection bucket is not sitting perfectly on the safety switch has to be down square I have the delonghi dem10 model always empty and unplug before checking
1/31/2019 4:45:46 PM • DeLonghi... • Answered on Jan 31, 2019
Your DeLonghi DE500P cannot condense wet air into water, although it forms icy blocks which blocks the flow of water.
Dear Heemin, From the wording which you have used, it appears you think you are talking to the DeLonghi company. You are not. You are speaking to "fixya:". Please contact DeLonghi or one of it's dealers by finding their access information on your computer's search engine. God bless your efforts.
7/5/2018 7:49:07 PM • DeLonghi... • Answered on Jul 05, 2018
Where can I get instructions for a DeLonghi dehumidifier model DDe 50e?
Free online manual: https://www.manualslib.com/manual/228038/Delonghi-Dde40e.html#product-DDE%2050E Delonghi DDE40E Use And Maintenance Manualhttps://www.manualslib.com/manual/254660/Delonghi-40eddh30.html#product-DDE%2050E
4/19/2018 11:35:27 PM • DeLonghi... • Answered on Apr 19, 2018
Good morning. I have a DeLonghi
Are you worried as to why there is no Water in the Water Tank/Bucket at all? Well, a few operational basics must be understood by you please. For the unit to remove moisture from the air and draw water into the bucket/tank, the set relative humidity (%RH) must be below the current or ambient room relative humidity. Attempt to lower or reduce the setting you have to a lower value and it should start collecting water in the tank. Hope this helps
11/20/2017 11:49:11 AM • DeLonghi... • Answered on Nov 20, 2017
Delonghi dehumidifier is not drawing in liquid, have run it all night but nothing and there is still mist on windows, can you please advise
It's basically an air conditioner so if the fan is running---the condenser not plugged up via rats nest---lint----the float switch working---if possible tip over switch working----the system maybe low on refrigerant
5/31/2017 1:52:31 AM • DeLonghi... • Answered on May 31, 2017
DeLonghi DN 125 Dehumidifier Logo
Popular Tags
5 questions posted
Top DeLonghi Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • DeLonghi Dehumidifiers
Most Popular Question
dehumidifier no longer
  • Dehumidifiers
