20 Most Recent
Culligan Sediment Water Filter Questions & Answers
How do you change the filter to a culligan water
Here are instruction to remove the filter housing. This is from my tips posting. Culligan filter housings are just Pentek/Pentair water filter housings and these tips apply to virtually any filter housing. Frequently whole house filters can be very difficult to remove. The
canisters become almost impossible to loosen, even after pressing the
pressure relief valve and using a housing wrench. The most common
reasons for this are the housing was put back on with the housing
wrench, debris in the housing threads and a bad pressure relief valve.
How to remove a stuck filter housing.1. Turn off the incoming water. 2. By-Pass the Softener3. Go to the nearest cold water faucet, open it and let the water run until pressure drops significantly.4. Turn the water off at outlet of filter (If housing has shutoff on top off head, turn this off now).5. Press and hold the pressure relief button to relieve pressure further.6. Use filter wrench to unscrew housing (If it still won't loosen repeat steps 2-5).7.
After removing, clean housing thoroughly, make sure threads are clean
on filter bowl and housing head. Lubricate threads of housing and head
with plumbers faucet lube or silicone. 8. Clean and lubricate the
O-Ring (replace the O-ring every couple years or if housing leaks after
screwing back on). It helps to flip the O-Ring over a couple times per
year. 9. Replace the cartridge filter and screw the housing back on. 10. Turn the incoming water on slowly while holding the pressure relief button down until all air is purged.11. Open outlet and let water run to cold water faucet until all air is purged.12. Put softener back in service.IMPORTANT! Only tighten the filter housing by HAND! NEVER use the housing wrench to tighten the housing. I hope these tips help you with the angst of removing stubborn filter housings.RJ
7/10/2018 7:21:01 PM •
Culligan...
Answered
on Jul 10, 2018
Water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
11/19/2014 12:19:17 AM •
Culligan...
Answered
on Nov 19, 2014
Water has been trickling to the drain
There is a problem with the main piston/sealpack assembly and it needs to be replaced. You can get this kit at Culligan and replace it yourself, if you are handy, it takes about 20 minutes. Replace the refill piston at the same time. Or have Culligan do it.
RJ
5/21/2014 3:30:47 PM •
Culligan...
Answered
on May 21, 2014
Panel says e 2
By-pass the softener, unplug the control for two minutes, plug back in, put unit back in service (return by-pass to normal position). If unit continues run it has a bad seal pack assembly in the valve and it would need to be replaced. Or if it is stuck in backwash cycle this may home out the board and return valve to service position. If neither works you will need to call for service.RJH2O
5/14/2013 1:20:53 AM •
Culligan...
Answered
on May 14, 2013
How do I clean the injector screen?
Cleaning injectors is a process best left to a professional with a bench setup to properly flow and clean them. In a pinch for a low cost short term fix you can do the following:1. Remove the + battery terminal.2. Remove the fuel rail retaining bolts and the injectors will pull out of their seat in the head.3. Remove the injector plug and simply pull them out. Look into the input side and you should be able to see if it is relatively clean. Sometimes they are completely clogged on older vehicles.4. Use Seafoam injector cleaner and spray into the input while pulsing the nozzle in and out until it is clear. Also spray some into the nozzle end.5. Repeat for all injectors, let them sit for an hour to 24 hours, then repeat the cleaning with the injector cleaner to force out any residual.6. You can also energize the relay with 12V and spray through the nozzle, but this is difficult without having a pressurized system.7. Reinstall (preferably with new O-rings) and enjoy. I did this recently on my son's 1999 Mitsubishi Mirage due to 2 cylinders not firing at all and it runs like a champ. Cost me $10.99 from Autozone. You should also replace the fuel filter at this time.
12/28/2012 12:17:38 PM •
Culligan...
Answered
on Dec 28, 2012
LeAking pressure valve on water filter h
Usually this is because iron/sediment has built up under the button up in the head of the housing. There is a spring that holds the button closed. If you can look up inside the head (with filter housing off) you will see a phillips head screw. Remove the screw and the spring and button come out. Clean the area thoroughly and lubricate lightly with silicone lube. Re-install and test to see if still leaking. If so you can try getting a new spring at hardware or replace the entire housing.RJ
11/11/2012 2:15:59 AM •
Culligan...
Answered
on Nov 11, 2012
