20 Most Recent Precor EFX 546i Elliptical Version 4 Questions & Answers
2answers
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer). 2. Lift position sensor (potentiometer) is bad. 3. Lower PCA is bad. Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
9/29/2022 6:12:21 AM • Precor EFX 546i... • Answered on Sep 29, 2022
I am looking for a parts and repair manual for a
Go to National Gym Supply @ gymparts.com or call them @ 1-800-496-7278
8/21/2020 2:54:25 PM • Precor EFX 546i... • Answered on Aug 21, 2020
Dead battery on Precor EFX 546i Elliptical -
This link will allow you to use your model and serial number to find the correct battery along with the service manual with replacement instructions. Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
6/25/2020 5:57:22 PM • Precor EFX 546i... • Answered on Jun 25, 2020
The display is showing "CK key" and the heart rate
Contact manufacturer/vendor Precord for assistance: https://www.precor.com/en-us/contact-us/customer-service
2/25/2020 2:09:43 PM • Precor EFX 546i... • Answered on Feb 25, 2020
Looking for the true service manual for a 576i EFX...I can find one for the C576i...but that is for the newer model
If you have your serial number, you should be able to find the service manual by using the following link. Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
5/8/2018 9:13:17 PM • Precor EFX 546i... • Answered on May 08, 2018
2answers
There is a squeeking sound when it's being used.
Sorry to say its time to replace the belts You may purchase them directly from Precor @ 1-800-347-4404 or
http://www.gympart.com or http://www.sportsmith.net
Have your serial number
10/28/2017 12:19:09 AM • Precor EFX 546i... • Answered on Oct 28, 2017
0answers
Precor 546i
Be the first to answer 4/23/2016 10:27:38 PM • Precor EFX 546i... • Posted on Apr 23, 2016Be the first to answer
Squeaking is definitely coming from the Ramp area
Tip it over - there was a version that had a problem with the frame cracking where the ramp attaches. There is a kit to fix this, if that is what you find. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
3/27/2016 12:17:27 AM • Precor EFX 546i... • Answered on Mar 27, 2016
How do you change the
Using your model and serial number, use this link to view a service manual with procedure instructions. http://www.sportsmith.net/
2/25/2016 2:38:10 AM • Precor EFX 546i... • Answered on Feb 25, 2016
2answers
Belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
1/22/2016 10:37:43 AM • Precor EFX 546i... • Answered on Jan 22, 2016
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**. Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket. Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket. Warning Notice for Battery Installation on Precor EFX Ellipticals
10/29/2015 7:30:58 PM • Precor EFX 546i... • Answered on Oct 29, 2015
Ramp is stuck
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH This is commonly caused by a bad overlay/keypad. The only solution to resolve this issue is to replace the overlay/keypad. Please use your model and serial number to find the correct replacement at the following link: Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH net
10/29/2015 7:30:07 PM • Precor EFX 546i... • Answered on Oct 29, 2015
How do I replace the battery on efx 546i
10/29/2015 7:24:40 PM • Precor EFX 546i... • Answered on Oct 29, 2015
Precor 546i screen won't light up
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Start by checking the voltage output from the battery. I am attaching a link to a video with instructions on how to test a battery. Video about How to Test Battery
10/29/2015 7:23:45 PM • Precor EFX 546i... • Answered on Oct 29, 2015
I want to replace the battery
10/29/2015 7:22:25 PM • Precor EFX 546i... • Answered on Oct 29, 2015
How do I replace overlay and key pads
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH You can find the overlay and keypad on our Website, using your model and serial number.
9/28/2015 4:10:07 PM • Precor EFX 546i... • Answered on Sep 28, 2015
2answers
The ramp will not go up or down and it doesn't
It doesn't always say low battery - check the battery first. If the battery is fine, then check the lower board and the incline motor. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
6/9/2015 10:57:54 PM • Precor EFX 546i... • Answered on Jun 09, 2015
Precor EFX 546i Elliptical Version 4 Logo
232 questions posted
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Precor Exercise & Fitness
Most Popular Question
squeaking definitely coming from ramp
  • Exercise & Fitness
