20 Most Recent Electrolux EW1000i Front Load Washer Questions & Answers
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
11/15/2020 2:41:18 PM • Electrolux... • Answered on Nov 15, 2020
2answers
Electrolux Eco Valve EWF1087 washing machine,will
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
9/22/2020 9:41:15 PM • Electrolux... • Answered on Sep 22, 2020
3answers
Ew1045f washing machine purchased in india.
try checking the carbon brushes.
3/4/2020 11:56:58 AM • Electrolux... • Answered on Mar 04, 2020
2answers
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
1/22/2019 6:59:44 AM • Electrolux... • Answered on Jan 22, 2019
2answers
Electrolux EWF 1074 - How do I turn off the annoying beeps at the end of every wash
I have touchscreen! Doesnt work. Any suggestions? Hate having to get up middle of night to turn off this )%(/₪/#&/₪(" beep!
9/23/2018 7:06:11 AM • Electrolux... • Answered on Sep 23, 2018
4answers
Electrolux 1087 E90
When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
what can i do ?
7/4/2018 4:30:24 PM • Electrolux... • Answered on Jul 04, 2018
3answers
Electrolux EWF1074 with Error EH0. After 2 seconds
In case of error in the mains, or like what happend today at my house, the power lines went partially down, providing too low voltage, EH0 or EH1 will occour. If you also notice that the lightning indoor is somewhat dimmed during this error, the voltage is too low.
10/22/2017 4:18:01 PM • Electrolux... • Answered on Oct 22, 2017
My ewf1074 runs for a few seconds then stops no error codes
Fualty out of balance switch or front door lock.
10/31/2016 7:56:50 PM • Electrolux... • Answered on Oct 31, 2016
0answers
My front load washing machine is working but the water don't seem to enter.
First of all check filters in hoses & water valves, if ok then water inlet valve may be burnt out. Unplug power cord, remove top panel panel, check where 2 wires go to each water valve & check that area on valves for burning. If burnt or smells of burning, replace valve. IN SOME INSTANCES A COMPONENT BURN OUT CAN CAUSE DAMAGE TO CONTROL BOARD.
4/28/2015 6:52:50 AM • Electrolux... • Answered on Apr 28, 2015
2answers
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error E90 and starts beeping and stops working? Any ideas how to fix it ? Thanks kindly
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes: Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds! After that the display will show one of the following errors that are more precise: E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board. E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty. E94 - Incorrect configuration of washing cycle. Posible causes: Incorrect configuration data; electronic board faulty. E95 - Communication error between microprocessor and EEPROM. Posible causes: Electronic board faulty. E97 - Incongruence between programme selector and cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data). Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics. Dado
2/14/2015 8:58:52 PM • Electrolux... • Answered on Feb 14, 2015
How to get the clothes to spin dry in Color wash mode?
Program the machine for white wash and turn down temperature and duration manually, and tune up the sentrifuge program to maximum RPM. It helps to use a machine with large drum and minimum 1600 RPM. Large diameter of the drum is more efficient than a small diameter drum at the same RPM.
2/4/2015 8:10:17 PM • Electrolux... • Answered on Feb 04, 2015
Error message e21
Machine tries to drain for 10 min (timeout) without emptying the tub. Possible fault: - drain pump - drain filter - drain hose - wiring between drain pump and electronic - electronic Dado
1/6/2015 6:26:33 PM • Electrolux... • Answered on Jan 06, 2015
I removed the soap dispenser from my front load electrolux and now i can't get it back in, help please
Thank you for your inquiry, cheryl!
I understand that you have removed your soap dispenser on your Electrolux washer and are having a challenge getting it back into place. It should go back into place once lined up. If you continue you having an issue I would suggest having a professional technician out to your home for proper install of the dispenser. Good luck. -Matt
12/19/2014 3:48:36 PM • Electrolux... • Answered on Dec 19, 2014
Electrolux EW1000i Front Load Washer Logo
440 questions posted
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Washing Machines
Most Popular Question
front load washing machine working but
  • Washing Machines
