20 Most Recent
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Questions & Answers
How do i adjust a clutch on a 1997 polaris xlt?
Remove the clutch cover then the spider (special tool required) there are some washers to add between the spider and engine side of clutch shaft to set pulley width. But before you do that when engine is off does belt have side clearance? If the answer is yes, you may only need a new clutch spring as they loose tension with time and idle speed may be engaging clutch
2000 rmk 600
You may have a sticky exhaust valve due to carbon build up on the stem.
I have a 2001 polaris RMK 700. It seems to use a
Certainly the carbs should be treated as a pair and so when one is suspected both should be checked. The cylinders will be unable to perform equally unless both carbs are tuned equally and synchronised at idle and at various throttle openings.
As part of the checking process it is important to ensure both cylinders are capable of performing equally. A compression test has limited use and a cylinder efficiency test is better. Injecting compressed air into the cylinder would prove the effectiveness of the valve seats and piston rings. A small amount of leakage of the inlet valve seat would make little difference to a compression test but it would make a great deal of difference to the way the cylinder performs.
Another important check is the valve clearances and also the ignition timing if it is adjustable. Some engines with twin ignition systems need to have the timing set for each cylinder.
How many turns should the air/fuel mixture screw be set at for a 1996 polaris ultra
Run machine and wind in mixture screw till it nearly stalls and wind it back out to 2 and a half to 3 and a half turns, you might have to then adjust the idle if by then its running. Quick jabs with the accelerate and by doing this which is like checking your timing, you can pick up by the engine running and as the revs drop back after a few times you can adjust to suit. screwed in to far and it will starve 4 air and you will have dark grey to black exhaust like having the choke on. IT comes down to screw in the mixture screw till it nearly stalls and wind back as i wrote up top, better a little richer than to lean [good luck] you will soon pick it up, more trial and error
Have 96 indy 500 want to know what would cause the
IT COULD BE A NUMEBER OF THINGS, I WOULD CHECK YOUR DIVE SHAFT AND JACK SHAFT BEARINGS, THAN YOUR CLUTCHES FOR WORN PARTS. IF THAT IS OK CHECK YOUR CHAIN AND SPROKETS. THAN DO A COMPRESSION TEST ON YOUR ENGINE.
1980 GSX1100 Carburators over fuelling starts fine revs freely at stand still - when riding gets to 4500 revs starts popping and pulling back.
By the sound of your description of the problem which was that at about 4500 RPM under load the bike starts 'popping and pulling back' it seems to me that you are experiencing a lean (not enough fuel) condition. Popping and 'pulling back' are indicative of a lean rather than a rich condition. Revving the bike in neutral does not use much fuel compared to trying to throttle it under load so testing it in neutral does not mean much.
Assuming that it is a lean condition that you are dealing with I would pull the carbs off and then remove the float bowls and check out the float valves under each float to make sure they are not partially gummed up and not allowing enough fuel to flow into the float bowls fast enough to keep up with the demand when the engine is under load. Also check the main jet in each carb to make sure it is clear. All the fuel from about 1/4 throttle opening and above goes through the main jet first but from about 1/4 to 3/4 throttle the fuel is then regulated by the needle jet and slide needle. After that, from 3/4 throttle and on, the main jet is the only form of fuel regulation. Either way all the fuel needs to get through the main jet first except at idle and right off idle as that is the pilot jet circuit so the main jets need to be clean and clear.
Also, as the bike is pretty old, when you have the carbs off you need to carefully examine the rubber intake manifolds that connect the carbs to the engine for cracks and splits. These manifolds should be replaced every 10 years or so as when they split and crack it lets air in through the splits and cracks and leans out the mixture going into the engine and will cause the same popping and 'dropping out' that clogged jets in the carbs will cause.
What is the torque specs on a 1927 model t head bolt
Ford didn't publish torque specs for anything on a model T but a good rule of thumb for the size of the model T bolts would be to cinch the bolts to about 30 lbs/ft and then finish each one to 50 lbs/ft. These numbers are for a 'dry' installation. That is to say screwing a clean but not oiled bolt into a clean but dry hole. Adding oil or anti seize to the bolt or hole can skew the torque readings a bit and if too much oil should find it's way into the hole one can find themselves trying to tighten a bolt against a hydraulic lock situation and really screw up the works. Fortunately the old model T does not pose much of a sealing problem as the cylinder pressure is low and all one is really concerned with is keeping the thing water tight.
