20 Most Recent
Electrolux EOB5665G Ultrafan Electric Single Oven Questions & Answers
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
Dado
Only one light comes on, nothing works
Your problem is related to incoming power or range internal wiring.
Verify 220 volts to the range. Pay attention to the wire connections being tight especially the neutral wire.
Light and fan come on but oven does not heat up
If the fan comes on, it will not be the timer, it will be the oven element not working.
Remove inner rear cover of oven, and you will see the element, remove screws and element, detach wires and fit on new element, be careful not to loose the wires behind rear of oven.
You may not see anything wrong with element, but the odds are that is the prob.
Please leave a fixya rating for my proposed solution.
Yhanks.
Overheating?
yes - it is cutting out on overheat. there are two fans - which one was replaced - cavity fan or casing fan?
possible reasons are:
faulty casing fan
not enough ventilation
faulty overheat stat
faulty fan stat
oven operating stat faulty but you would be burning your cooking in this case
ELECTROLUX EOD5310
there are two fans and one is out of sight and is to cool the casing. normal for the casing fan to run for up to 20mins after switching off. after 4 years, maybe getting a bit worn and hence noisy. nothing to worry about
Electrolux Oven 5d or Sd error code/demo mode
- Turn off the oven.
- Press and hold the "Bake" and "Broil" buttons.
- Turn the oven on by pressing the "On/Off" button.
- Continue holding the "Bake" and "Broil" buttons until the display shows "PF" or "8.88."
- Release both buttons.
If these steps don't work, refer to the user manual or contact Electrolux customer support for further assistance.
