20 Most Recent LG WM2233H Front Load Stacked Washer / Dryer Questions & Answers
LE error on washer. What can I do without a tech?
The *dreaded* "LE" error is overwhelmingly caused or triggered by incorrect type detergent **OR** too much *HE* detergent (a special low sudsing detergent). In all LG washers-when too much detergent has been used-this will cause the "LE" error to be displayed & the wash cycle will be interrupted. Unplugging the washer for more than one minute will cause the MAIN BOARD (computer) to power down and re-boot when the washer has been plugged back in. On LG washers built *before* 2008-after several "LE" error events-the error *cannot* be reset by unplugging the washer. This indicates that the HALL EFFECT SENSOR has failed and will need to be replaced. On all LG washers built during and after 2008-a more robust resistor was used in the HALL EFFECT SENSORS-which eliminated damage caused by higher electrical loads placed upon the sensors due to oversudsing. HALL EFFECT SENSORS virtually never fail in 2008 and newer LG washers but the "LE" error will still occur if too much or the wrong type of detergent is used. This will be "resettable" by unplugging/replugging the washer. The CORRECT amount of HE (High Efficiency) detergent to be used is as follows: HE : (2) Tablespoons Per Wash Load HE 2X : (1) Tablespoon HE 3X : (1) Teaspoon USE THESE AMOUNTS RELIGIOUSLY-NO EXCEPTIONS-IN ALL FRONT LOAD WASHERS WITH 3.0 cu ft DRUMS AND LARGER Read more: The Dreaded LE Error Code in LG Washing Machines: Diagnosis / Troubleshooting, Root Causes, and Repair ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2010/08/03/the-dreaded-le-error-code-in-lg-washing-machines-diagnosis-troubleshooting-root-causes-and-repair/#ixzz2nlabX1Gv Follow us: fixitnowsamurai on Facebook
4/7/2018 4:42:41 AM • LG WM2233H Front... • Answered on Apr 07, 2018
How to just spin only?
turn power on. then just hit spin speed button. do not touch selection knob. then start.
9/25/2016 3:23:07 AM • LG WM2233H Front... • Answered on Sep 25, 2016
How do I reverse the door on my lg front load washer from left side to right side?
You cant reverse the washer door. only on dryers.
5/30/2015 10:53:06 PM • LG WM2233H Front... • Answered on May 30, 2015
My WM2233H will not show any kind of power suply and we have tripped the house fuses and checked the outlets they all work fine. what could it be and how do I check it?
WASHER WILL NOT START: Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary. Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch.. If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start. Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself. Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly. Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on. The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings. By the way my advice is free cuz God is good! All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced Lastly CONTROL BOARD If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
5/25/2015 11:44:49 PM • LG WM2233H Front... • Answered on May 25, 2015
Why is my wash machine display out?
chek doorinterlock
2/23/2015 10:24:14 PM • LG WM2233H Front... • Answered on Feb 23, 2015
0answers
It has a horrible odor.
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
If the standing water is your fabric softener you'll have to clean it out to unstop it so it will drain.
Here's a DIAGRAM which may help with the cleaning.
6/5/2014 2:21:09 AM • LG WM2233H Front... • Answered on Jun 05, 2014
Dark streaks after washing
This has been a problem with LG front loading washers for quit a while, unless its in warranty I would not spend the money for repairs . Buy a good basic model heavy duty top loading washer for around $500.
9/16/2013 2:34:25 AM • LG WM2233H Front... • Answered on Sep 16, 2013
0answers
08006623
Be the first to answer 7/22/2013 3:14:47 AM • LG WM2233H Front... • Posted on Jul 22, 2013Be the first to answer
Wont spin all water out of clothes
Check the drain, or could be the control panel fault
3/26/2013 3:54:17 PM • LG WM2233H Front... • Answered on Mar 26, 2013
OE error on washing machine LG WM2233HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out.A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.LG themselves have some information on this error code.. CLICK HEREThanks
11/2/2011 7:12:17 PM • LG WM2233H Front... • Answered on Nov 02, 2011
LG WM2233H WATER LEAK
The first thing to do is to have the leak investigated by somebody actually there as we could only offer a list of guesses ;-0)
Once it is empty and carefully lifted onto its side, it should be possible to inspect the hoses and clips and hopefully identify the culprit. In some cases it might even be possible to affect at least a temporary fix whilst obtaining the necessary spare.
Sorry we could be only of limited help in this instance- it's very difficult diagnosing this sort of problem remotely ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
9/9/2011 3:15:41 PM • LG WM2233H Front... • Answered on Sep 09, 2011
LG WM2233H Front Load Stacked Washer / Dryer Logo
62 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
reverse door lg front load washer from
  • Washing Machines
