20 Most Recent Arctic King 10,000 BTU Slide Casement Air Conditioner Questions & Answers
I want to buy a new ac filter for the Arctic King model WWK05CR61N. Do you sell them since I can't find them anywhere?
Hello, Alex - Fixya.com does not sell ANYTHING. It is a website intended for asking and answering questions on how to go about REPAIRING THINGS. I would try to find a business which sells the air conditioner filters for your model of Artctic King air conditioner if I knew where (what country) you resided. Fixya receives questions from people worldwide. You can choose comment and type your country of residence in the Comment box. I am answering from the USA. Best wishes.
1/30/2019 6:01:31 PM • Arctic King... • Answered on Jan 30, 2019
What does it mean when the clean filter come I washed fliter
Its sign of you air con filter has been dirty need go clean it .
8/7/2016 9:07:19 PM • Arctic King... • Answered on Aug 07, 2016
Purchased september 2015 air is cold but fan is extremely LOUD
if it was purchase new then a warranty still applies so have the unit checked by a service agent under warranty
5/4/2016 12:35:15 AM • Arctic King... • Answered on May 04, 2016
There is an exhaust switch on the front of the unit. (open or closed position). When should each be used?
exhaust when you want to change air inside room more than you want cooling and dehumid efficiency. It ports air to outside, to be replaced by air from the outside (often from elsewhere in house, rather than via the AC unit). Does that answer it?
5/2/2014 9:35:20 PM • Arctic King... • Answered on May 02, 2014
What is the consumer telephone number for Arctic King Air Conditioners?
This is what is provided to US customer service: Contact Us It has the phone numbers, fax numbers, and a way to email them.
5/18/2017 2:18:05 PM • Arctic King... • Answered on May 18, 2017
0answers
WE HAVE A FEDDERS AZ7A09W2A Through the Wall Room Air Conditioner. IT WILL NOT TURN OFF. PULLING THE POWER CORD IS THE ONLY WAY. DOES ANYONE KNOW THE CAUSE AND OR REPLACEMENT PART?
Question edited for clarity, full 'make model (what it is)'. Email address removed. You don't need the site's 12 million annual viewers emailing you to say they can fix it for a thousand bucks! Finally, Please don't type in all CAPS, it is considered SHOUTING and is harder to read. Repair Clinic has some good ideas, but your model is discontinued
Fedders Air conditioner won't turn off
Repair Clinic https://www.repairclinic.com > RepairHelp > Fedders-Ai... Here are the most common reasons your Fedders AC compressor won't turn off - and the parts & instructions to fix the problem yourself.
Why Your Air Conditioner Isn't Shutting Off, and How to Fix It
Williams Comfort Air https://williamscomfortair.com > ac-wont-shut-off When your air conditioner won't shut off, it's natural to worry about wasting electrical power as temperatures become too cool for comfort. ..
4/24/2024 1:44:56 AM • Heating &... • Answered Yesterday
2answers
I have a Bonair evap aircon model VSL75 with the comfort controller and I want to reduce the water dumping cycle down. I have tried the manual but that sequence didn't work.
Here are the steps you might want to follow: Setting the Draining Cycle Times (Dump Interval): This setting controls how often the unit dumps the water. You can adjust this setting to reduce the frequency of water dumping. Setting the Drain off Delay Time (Dump Delay): This setting controls the delay time before the unit starts to dump the water after it has been turned off. If adjusting these settings doesn't work, there could be other issues with your unit. For example, a continuous water dumping problem could be due to a faulty dump valve or a problem with the float valve.
4/21/2024 11:19:53 PM • Heating &... • Answered 3 days ago
What is E3 in frego split ac
Frego split ac error code h3 what is problem
4/16/2024 4:25:39 AM • Heating &... • Answered on Apr 16, 2024
2answers
What does E2 code mean on electric infrared heater
Model 2320cpb. E2 code
4/13/2024 11:00:34 AM • Heating &... • Answered on Apr 13, 2024
HP error code in bluestar split ac
Blue star inverter Ac HP error shown on display
4/10/2024 7:14:47 AM • Heating &... • Answered on Apr 10, 2024
Arctic King 10,000 BTU Slide Casement Air Conditioner Logo
4 questions posted
Top Arctic King Heating & Cooling Experts
Paul Carew
john h
Are you an Arctic King Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Arctic King Heating & Cooling
Most Popular Question
exhaust switch front unit open or
  • Heating & Cooling
