20 Most Recent Konica Minolta Bizhub C300 All-In-One Printer Questions & Answers
Getting magenta background when photocopying
replace the magenta image unit
10/24/2022 8:09:59 PM • Konica Minolta... • Answered on Oct 24, 2022
C-dc30 how to reset code
Sir/Mam, You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since someone attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inoperative , once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine now a day have Bank Note chips.
4/3/2020 10:49:46 PM • Konica Minolta... • Answered on Apr 03, 2020
How to stabilize my bizhub c300
its done automatically and you can do it in the service mode
2/18/2019 5:27:49 PM • Konica Minolta... • Answered on Feb 18, 2019
Konica minolta c300 error c2555
replace the yellow image unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/25/2018 9:17:43 PM • Konica Minolta... • Answered on Mar 25, 2018
2answers
Bizhub c300. Loud clicking sounds like coming from computer. Replaced transfer belt, fusing unit, clicking is 'pre-paper movement' on printing. Any ideas?
could be the HDD. could also be a gear issue have tech come out Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/11/2017 11:51:15 PM • Konica Minolta... • Answered on Mar 11, 2017
C2552 error
cyan image unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/10/2016 4:22:06 AM • Konica Minolta... • Answered on May 10, 2016
I have a bizhub 300C. When I print a pdf the top inch is faded
Mike does this happen with all prints? does it go away if you change the orientation of the paper. portrait to landscape? Happen when you copy ? Try different file type does that change? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/5/2016 11:09:49 PM • Konica Minolta... • Answered on May 05, 2016
Error C3452
1. Turn OFF the main power switch. 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/5/2016 11:07:02 PM • Konica Minolta... • Answered on May 05, 2016
Faded printint and copying at top of page
replace the fuser unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/3/2016 11:03:22 PM • Konica Minolta... • Answered on May 03, 2016
Bizhub c300 white stripes
clean the print head glasses Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/3/2016 10:55:53 PM • Konica Minolta... • Answered on May 03, 2016
COMPUTER WONT CONNECT TO PRINTER
the cable will not connect to the copier????? do have the print drivers for this model machine try this site Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/19/2016 11:33:52 PM • Konica Minolta... • Answered on Jan 19, 2016
P7 p28 p5 c300
For P-7 replace the magenta image unit for P-5 and P-28 unless you know your way around Konica Minolta Copiers you need to have the two sensor located below the transfer belt on the right side cleaned and or replaced, to clean them you must uncover them because when the belt assy. is remove the are covered. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2016 10:40:04 PM • Konica Minolta... • Answered on Jan 10, 2016
What is the ip address of Bezhub printer C300
i dont know it your network???? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2016 10:13:41 PM • Konica Minolta... • Answered on Jan 10, 2016
Lines in colour copy
then replace the image units for those colors Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2016 9:43:14 PM • Konica Minolta... • Answered on Jan 10, 2016
How do i reset cf023 code malfunction
have the printer control board firmware re-flashed by Tech because firmware is only available via secure Konica Minolta web site they keep their firmware secure, Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2015 9:59:07 PM • Konica Minolta... • Answered on Dec 30, 2015
How to fix
1. Turn OFF the main power switch. 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/29/2015 4:19:06 AM • Konica Minolta... • Answered on Dec 29, 2015
How to fix error c9401
Exposure lamp failure to turn on, raise the doc feeder hit the start button bright light come on under the big glass if not replace the exposure lamp and board if required. reset procedure if code comes back get the lamp 1. Turn OFF the main power switch. 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/29/2015 4:18:54 AM • Konica Minolta... • Answered on Dec 29, 2015
How to reset fuser error konica 7030
In your case the soft switch will be 3-1-1 changing last bit to 0. if the code comes back do not reset as this code deals with the fuser it can catch on fire and that will ruin a perfectly good day. Setting Software DIP SW1. Setting methodThis setting specifies the software DIP switch on the software SW setting screen. (*1)Caution 1: The bit of the DIP switch is written in the non-volatile memory every time it is changed. Caution 2: The numbers shown in the message area are defined as follows: Software SW 8-bit switch values in indicated in hexadecimals from 00 to FF. Example: 04-7 : 1 A8 Bit data 1 : ON 0 : OFF Bit number (0 to 7) Switch number 2. Setting proceduresStep1 Operation procedure Enter the 25 Mode.[25 mode menu screen] Hold Down the 25 and power on. Press the [1. Software SW] key.[Software SW setting screen]Select DIP switch number.Use the left [  ] , [ ] key. Select bit number of the DIP switch.Use the center [  ] , [ ] key. Select ON (=1) or OFF (=0) of the DIP switch. Use [ON] or [OFF] key. [ON] : Set bit. [OFF] : Clear bit. Press the [Return] key to return to the 25 mode menu screen.For each switch function, refer to "List of Software DIP switches". 25 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/28/2015 10:24:00 PM • Konica Minolta... • Answered on Dec 28, 2015
Konica Minolta Bizhub C300 All-In-One Printer Logo
78 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
codes f 34 f 35
  • Office Equipment & Supplies
