20 Most Recent Goodman CKL36AR36 Air Conditioner Questions & Answers
2answers
Model CKL36-IL was installed just
Factory parts warranty is five years all parts one year labor. Capacitor and/or fan motor has gone out and will need replaced. The breaker will throw itself off if the condition gets bad enough. Suggest not using until repaired, turn off breaker.
10/30/2018 10:39:38 PM • Goodman... • Answered on Oct 30, 2018
3answers
Fan on outdoor a/c unit not running
call in the technicians compressor shutting down or power to the fan being interrupted causing the compressor to shut down
1/23/2018 3:21:06 PM • Goodman... • Answered on Jan 23, 2018
Piston on evaporator coil which way does it go
point of piston goes toward coil
8/18/2015 12:09:01 AM • Goodman... • Answered on Aug 18, 2015
Goodman GSC130421ab has no voltage to contact after washing coils....it worked just before powering off unit at diconnect to clean the condenser coils
there is a 3 amp automotive type fuse on circuit board to protect transformer in air handler
8/14/2015 10:23:32 PM • Goodman... • Answered on Aug 14, 2015
Ac fan stas on
fan relay stuck in.
8/14/2015 9:11:24 PM • Goodman... • Answered on Aug 14, 2015
High pressure reset
most dont have a high pressure safety. the compresor trips on internal drawing to many amps.
8/14/2015 11:36:15 AM • Goodman... • Answered on Aug 14, 2015
WILL NOT RUN WHEN TURN ON THERSAT IT MAKES BUZING NOISE
contactor bad.
8/14/2015 11:27:30 AM • Goodman... • Answered on Aug 14, 2015
Why does a/c come on for 1-2 min then cuts out thermostat says cooling delayed 5 min and count down then starts cooling then cuts out again
ihe 5 minute delay is to prevent damage to your compressor. some safety is shutting it down.
8/14/2015 11:18:11 AM • Goodman... • Answered on Aug 14, 2015
Central air fan is running slow and will not start without help
try a new capacitor
8/12/2015 11:39:35 AM • Goodman... • Answered on Aug 12, 2015
Water is leaking from the air handler in the
stopped up drain or rusted out pan. should have auxiallry pan under a/c air-handler.
8/12/2015 11:16:56 AM • Goodman... • Answered on Aug 12, 2015
Leak in air handler goodman aircondition
drain pan stopped up or rusted through. if you are talking freon leak has to be repired by a pro.
8/11/2015 10:31:35 AM • Goodman... • Answered on Aug 11, 2015
Why would my central air unit blow warm air and not cool the house?
either you have refrigerant leak or compressor bad.
8/11/2015 10:03:13 AM • Goodman... • Answered on Aug 11, 2015
Ck24-18 isnt cooling. changed capaciator and still nothing? could it be the contactor
on the side of compressor is a plastic snap on cover. behind cover are 3 terminals labeled r for run c for common and s for start. make sure a wire has not burned off. remember power has to be off and capacitors store a charge that can hurt you.
8/9/2015 7:23:29 AM • Goodman... • Answered on Aug 09, 2015
I HAVE A FREON LEAK DOES IT MEANS MY COILS ARE BAD
possible but i would check line set first.
7/5/2015 12:43:13 AM • Goodman... • Answered on Jul 05, 2015
2answers
Need wiring diagram on compesor
The compressor has three terminals, Common, Start and Run.... The terminals read left to right, top to bottom just like pages in a book. So if theres one on top, its Common then Start will be the first one in the next row. If theres two on top, it'll be Common on the left and Start on the right then Run on the bottom. The run capacitor wires in between Start and Run and line voltage is applied to Common and Run.
4/14/2015 11:48:33 PM • Goodman... • Answered on Apr 14, 2015
Need compressor wiring diagram
Wiring diagram is on the inside of the service panel on the condensing unit.
4/11/2015 5:44:44 PM • Goodman... • Answered on Apr 11, 2015
How to put in frion
Freon can only be added to a refrigeration system by an EPA qualified technician
3/26/2015 4:26:31 AM • Goodman... • Answered on Mar 26, 2015
I need wiring diagram for goodman AC unit heatpump/electric
The wiring diagram is on the inside of the door on the blower/air handler unit.
1/8/2015 4:29:56 PM • Goodman... • Answered on Jan 08, 2015
Goodman CKL36AR36 Air Conditioner Logo
217 questions posted
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Goodman Heating & Cooling
Most Popular Question
outside ac unit not blowing goodman dk
  • Heating & Cooling
