20 Most Recent
Goodman CKL24AR24 Air Conditioner Questions & Answers
Condenser fan running backwards on heat pump
I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
11/15/2015 5:09:18 AM •
Goodman...
Answered
on Nov 15, 2015
Compressor not working on 2003 vw passat what do i need to do
You can try recharging, the refrigerant system has an electric switch for low pressure cut off that won't let the compressor turn on when there is not enough gas pressure. There is also a coolant temperature electric thermo switch that cuts off the compressor when the coolant or engine has overheated. If it's not low on refrigerant gas, then an electric problem needs to be diagnosed. A service or repair manual would then come in handy.
5/5/2015 5:02:39 AM •
Goodman...
Answered
on May 05, 2015
How to tell if the compressor on your ac unit is running
If you have a split unit, it is fairly simple, just feel the small refrigerant line coming out of the unit. The temperature should be warmer than the surrounding air. If is not running the temperature will be the same as the surrounding air. If you have a package unit, take off the access cover to where the compressor is located. Find the compressor discharge piping to the the condensing coil. It is the smaller of the two major pipes on the side of the compressor. Be careful the temperature of line coming out of a properly operating compressor will be hot enough to cause second degree burns. If the line is very warm to very hot the compressor is running. If you have a set of gauges, attach the RED hose to the high pressure service connection and the other low pressure hose BLUE to the bigger pipe low pressure connection. Make sure the gauges are isolated by shutting the valves. The pressure difference between high and low pressure is normally at least 150 psig diference.
10/14/2014 12:47:19 AM •
Goodman...
Answered
on Oct 14, 2014
Where's the reset button on a Goodman air
I believe that the higher end units have auto reset pressure switches, if you look down the inside of the unit, you will see one or two pressure switches welded to the lines,,,there are about the size of a "C" cell sized battery, with 2 wires running into them, if it is a manual reset type there will be a small rubber coated button on top, between the 2 wires.
If this has been helpful, please rate me, and/or contact me back with any further questions.
Sincerely,
Paul Gibson
9/23/2014 9:40:30 PM •
Goodman...
Answered
on Sep 23, 2014
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
7/1/2014 8:35:30 PM •
Goodman...
Answered
on Jul 01, 2014
Inside blower grinding on housing
turn off power remove blower housing (screws and wires) use a crescsent wrench to loosen bolt and reset wheel on shaft in the center of housing and then retighten bolt be sure to set it on the flat part of the shaft then reinstall in reverse order
5/16/2014 6:43:07 AM •
Goodman...
Answered
on May 16, 2014
