20 Most Recent Sage Instant Accounts 8.0 (013604ug) Questions & Answers
2answers
How to change the font
Press and hold the Ctrl button, then press the + and - keys to change the size of the font key. You can also press Ctrl and use the mouse wheel.
2/23/2024 8:37:25 PM • Sage Instant... • Answered on Feb 23, 2024
2answers
Hello Please can you help. We
This is usually caused by the user not having full rights to the Data directory. right click on the data director select security and you can a click on users network logon and tick on full control
10/18/2019 10:53:56 AM • Sage Instant... • Answered on Oct 18, 2019
2answers
SAGE is not loading
It sounds as if flash or java have a problem, try updating both and then post the reults
10/18/2019 10:52:10 AM • Sage Instant... • Answered on Oct 18, 2019
2answers
Serial Number & Activation Code
Need to know what version it is. You should get this before you are asked for an activation key
10/18/2019 10:47:47 AM • Sage Instant... • Answered on Oct 18, 2019
I was working in sage
If you are unable to logon to Sage you can try deleting the Queue.dta file. All users MUST be logged out of Sage and Sage should not be running. Sage will recreate the queue.dta file when it is restarted. The Queue.dta file can be found in the ACCDATA folder for the Sage Company Data that is experiencing the problem.
Note that the "Username already in use" message from Sage can occur if Sage wasn't shut down tidily for that users session. If you are sure that the user is not actually logged in it's OK to allow Sage to clear the session and log in.
5/7/2019 5:38:38 AM • Sage Instant... • Answered on May 07, 2019
3answers
My sage accounts wont open i keep getting user
Make sure there is no other user that has the program open (if it is on a network). Shutdown the computer and restart the program. Make sure you have all the Windows updates installed.
11/27/2018 9:21:53 AM • Sage Instant... • Answered on Nov 27, 2018
2answers
I have been using Sage Instant Account for 4
If sage doesn't prompt you to clear the user you can manually delete the queue.dta file from your data directory
10/27/2017 9:44:32 AM • Sage Instant... • Answered on Oct 27, 2017
Instant Accounts 8.0 (013604ug): I am using Sage Instant Accounts version 8 and am ...
Hi.
We had same problem. Our solution:
1. Empty both the 'accdata' and the 'criteria' folders.
2. Start Sage.
3. Restore a previous backup.
This worked for us. Hope it helps you.
12/13/2016 8:41:43 PM • Sage Instant... • Answered on Dec 13, 2016
2answers
Error message with sage instant accounts
2/4/2016 3:38:44 PM • Sage Instant... • Answered on Feb 04, 2016
I have restored a later version of Sage over an earlier one and i get an error message
Uninstall all the Sage software and reinstall the correct version.
8/10/2014 10:53:16 PM • Sage Instant... • Answered on Aug 10, 2014
C:\program\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid pat
This message usually comes when the target location is not there or is renamed OR the address is wrong. Open My Computer, and go to the address you gave. Look if there is the file named *TB.SRT.
And by the way... the address you gave was "
C:\PROGRAM\\SAGE\ACCOUNTS\REPORTS\\*TB.SRT" BUT I believe that the address should be "C:\PROGRAM\SAGE\ACCOUNTS\REPORTS\*TB.SRT".
It is not possible that the address contains 2 slash (\\) repeatedly. Open the file by going to the My Computer OR by opening the software and by locating the file manually from there.
live chat assistance costs $19.99. And $12.99 for one time e-mail premium support.
If you have a registered product then I would suggest you to visit:
http://support.sage.co.uk/default.aspx?page=1
There you might find a solution at no cost.
Please inform if your problem is solved or not. And please rate if you found the above info useful.
2/20/2014 12:40:42 PM • Sage Instant... • Answered on Feb 20, 2014
Activation key
hi my code is and what is the activation code greatful. help me please. (654812-C774-EB9B)
11/29/2013 8:34:59 AM • Sage Instant... • Answered on Nov 29, 2013
Applying change to vat rate
I installed Sage Payment Gateway over a Magento website last year and got to come the same kind of problem for shipping in UK. I think you need to upgrade your Sage software to PRO if its free one as their free versions are not sufficient enough to get the work done.
7/12/2013 2:15:39 AM • Sage Instant... • Answered on Jul 12, 2013
Sage line 50
You can use this tool www.backupmanager.webs.com
4/10/2013 4:53:23 PM • Sage Instant... • Answered on Apr 10, 2013
Sage v12.00 is asking for a serial and activation
plz some one send me Sage Accounts V12.00 serial number and activation keymy [email protected]
11/23/2012 9:25:41 AM • Sage Instant... • Answered on Nov 23, 2012
I am trying to get
Press CTRL-ALT-DELETE and close any process related to this program. If you cannot determine which process is related to this program, reboot and run your program again.
7/30/2011 1:32:42 PM • Sage Instant... • Answered on Jul 30, 2011
Trial Balance does not balance
Hello.
Even though these suggestions are for manual entry, they may be useful in troubleshooting this problem:
How To Find Trial Balance Errors
  1. Check the totaling of the debit column and the credit column. It is very easy to make an error when totaling a large column of figures therefore this is an obvious place to start.
  2. Calculate the difference between the debit and credit totals as this may come in useful later in the checking exercise if the difference cannot be found easily.
  3. Check that each balance in the trial balance has been correctly copied into the trial balance and that each has been included on the correct side, debit or credit.
  4. Check that all balances in the main ledger have been included in the trial balance. In particular ensure that the bank balance and petty cash balances have been included, as these are generally kept physically separate from the main ledger.
  5. Check that the calculation of the balance on each ledger account is correct.
  6. Look in the ledger accounts for any entry that is for the same amount as the difference on the trial balance and, if it is found, check that the double entry for this transaction has been correctly carried out.
  7. Look in the ledger accounts for any entry that is for half the amount of the difference on the trial balance and, if it is found, check that the double entry for this transaction has been correctly carried out.
Hope this helps.
6/5/2011 3:11:34 PM • Sage Instant... • Answered on Jun 05, 2011
WE have upgraded a sage
hi dmatharu667
this happens when you take a backup of a company that has a accdata folder in the accdata folder and it reports version as v9. To correct this go to data directory go into accdata directory and in that director move or delete the second accdata directory, repeat your backup and it should then restore perfectly
Nigel
6/1/2011 11:39:32 AM • Sage Instant... • Answered on Jun 01, 2011
Wrong date on sage accounts plus
go to settings and financial year click on change button and change year.
5/16/2011 8:56:59 AM • Sage Instant... • Answered on May 16, 2011
Hy000 fails to supply data
check your data formating
3/20/2011 1:29:57 PM • Sage Instant... • Answered on Mar 20, 2011
Computers & Internet Logo
145 questions posted
Top Sage Computers & Internet Experts
vince
john h
Arnie Burke
Arnie Burke
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sage Computers & Internet
Most Popular Question
working in sage
  • Computers & Internet
