20 Most Recent
LG WM2016CW Front Load Washer Questions & Answers
How to restart?
normally pressing and holding start or stop will reset .removing drain hose from wall and holding at ground level will empty all washing machines.so have it in a bucket.either its not level so adjust feet so it cant rock about then dont overload it turn drum as u load that will help balance.
Runs fine. Won't unlock clicks 3 times and won't open
If you take the 3 screws off the back of the top metal panel and slide it back the door lock has a release cord you can pull to get your clothes out. You will need to replace the door lock if the problem continues.
If you need help finding the right part number let me know.
How do I fix a loose or locked up drum that generates LE errors?
you sure it is not and upside down 'F' instead of an L? that would be a hall sensor(motor position sensor) error. easy fix. check out appliancepartspros.com or repairclinic.com for both parts and videos that show how to repair. very easy with common tools. about 20-30 minutes. basically take back cover off, remove motor cover, remove stator, replace part.
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E
WM2016CW
WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
How to bypass door lock on wash machine
This type of washer spins at high speed and would break your arm if you put it in the washer while it is spinning. Bypassing the lock is not be a good idea. If you want to bypass, you will need a wiring diagram.
LG Front Load Washer stopped mid-cycle, error code PF for power failure. Unplugged/restarted and still not working. Machine will power up, dial lights up then shuts off altogether with no diagnostic c
u have a faulty electronic board,,,,,,,,,,,,front panel.
How do you fix the rear tub spindle on an lg wm2016cw?
If its the main drum bearings gone then this will entail a complete strip to access them. The parts are available online, just have your serial no, model etc ready and trawl through various web appliance sites to find the best price. You will need a fair amount of mechanical / DIY knowledge to carry out this task. There are lots of parts and electrical connections.
WHY IS WATER IS LEAKING FROM WASHER?
you just have to pull it out and take back panel off start filling with water and watch and see where it coming from a few rubber hoses under there or water pump.
Bearing noise in a lg washer
Check your owners manual, some models warranty the rear tub that houses the bearing and the inner spin basket. If not the rear outer tub and the gasket between both tubs will have to be replaced the correct the problem. If out of warranty it may not be cost effective to repair.
