20 Most Recent
Android Zte-z990 Questions & Answers
NO sound when i receive a text message, how do i fix it?
First make sure that all volumes are all the way up. Go to settings, sounds, and rise up all of the volume.
Second, select a notification sound for your default notification, go to settings, sounds, notifications, tap it and choose a notification sound.
Third, whether you are using the native messenger or a third party messenger, go to the messenger settings, notifications sound and choose a sound for it.
if possible, download Zedge, this will help you choosing different ring tones and notifications sound.
Rethink possible loop when I power up
Try this:•Connect the phone to your computer with a USB cable that came in the sales package with your Lumia phone. If the battery has not been used for a long time, to begin charging, you may need to connect the cable, then disconnect and reconnect it.•Press and hold the Power button for 10 seconds, and then press to turn on your phone again.•Your PC should detect your phone when it is connected using a USB cable, if this is not happening you can manually switch the phone into specific mode following these steps:1. Disconnect your phone from the USB cable.2. Hold down the camera button. 3. Continue holding down the camera button and connect the USB cable between your phone and PC.4. Continue holding down the camera button until you see the connect-to-computer screen on your Lumia phone display.5. Release the camera button.6. The Zune software on the PC should automatically detect your phone now and charging indicator appears on the display.If the tricks above does not help, you will need to contact your local Nokia Care. You can find details by clicking the Contact us link in the support pages of the Nokia website for your country.Note: Your battery has been partially charged at the factory but when taking your new device into use, please keep the charger connected for 30 minutes. It is recommended to use original charger (AC-16).
How do I unlock my android vortex hd65 I need the me number how do I get it?
To find the IMEI number of your Android Vortex HD65, you can typically locate it in one of the following ways:
1. Dial *#06#: You can dial *#06# on your phone's keypad, and the IMEI number will be displayed on the screen. or
2. Check the phone's settings:
Go to Settings
go to About phone
Look for the "Status" or "Phone status"
you should find the IMEI number listed.
3. If you have the original box or documentation that came with your phone, the IMEI number may be printed on a sticker or label.
4. If your Android phone has a removable battery, you may find the IMEI number printed on a sticker underneath the battery.
Good Luck
Smart phone touch screen TOO sensitive
I'm sorry to hear that you are having trouble with your phone during calls. It sounds like there might be a couple of different issues at play here.
Firstly, it is possible that you are accidentally touching the touchscreen with your ear, jaw, or cheekbone, which can mute or end the call. This is a common problem, especially for those who are new to using smartphones. One solution is to try holding the phone a little further away from your face or use a hands-free headset or earbuds to keep the phone away from your face.
Secondly, it is true that many phones have a feature that locks the touchscreen during a call to prevent accidental touches. However, this feature may not be enabled on your specific phone or may not be working properly. To check if this feature is enabled on your phone, go to your phone's Settings app, select "Accessibility," and look for an option called "Power button ends call" or something similar. If this option is enabled, it should lock the touchscreen during calls. If the option is not available or not working, you may need to contact your phone's manufacturer or your carrier for assistance.
Lastly, if neither of the above solutions work, there may be an issue with your phone's hardware or software that is causing the problem. In this case, it may be best to take your phone to a professional for diagnosis and repair.
I hope this information helps you resolve the issue with your phone during calls.
Aftron AFLED4310 Smart tv
If your TV is still not working after disconnecting it from power and waiting a few hours, then it is likely that the files that were deleted were essential to the TV's operation. In this case, it is likely that you will need to have the TV serviced by a qualified technician.
Tv tap error kodi
You can restart and/or shut off your phone for a while. You could also take out the battery for a while, if you can.
My android heos app is not finding my maranta receiver
If your Android HEOS app is not finding your Marantz receiver, there are a few things you can try:
- Make sure that your Marantz receiver and your Android device are connected to the same Wi-Fi network.
- Check that the HEOS app is up to date by going to the Google Play Store and checking for updates.
- Try resetting your Marantz receiver by unplugging it from power, waiting a few seconds, and then plugging it back in.
- Check that your Marantz receiver is set up properly. Refer to the user manual for instructions on how to set up the receiver.
- If none of these steps work, try turning off your router and mobile device and then restarting them.
- Try disabling and re-enabling the wifi settings on your android device
- Check if the latest firmware update is installed on the Marantz Receiver
These steps should help resolve the issue. If the problem persists, you may need to contact Marantz support for further assistance.
