20 Most Recent
Haier HVT12ABS Compact Wine Cooler Questions & Answers
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Door does not close properly
if the door gasket is not ripped you may try taking a hair dryer to the ares that dont seem to be touching the frame of the cooler. Hold the hair dryer about 6 inches away from the gasket and move it back and forth slowly taking care not to melt the gasket or any of the sourrounding plastic.
