20 Most Recent
Light Outboard Motor Boat Bass Fishing Saltwater Base Questions & Answers
Yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
Ocean Runner 150 will idle and get to approximately 1400 rpm then dies out. It will restart in one minute or so.
Question edited for a lot more clarity.
It is likely to be fuel starvation. Check the following;
The tank vent.
The pump bulb is the right way around, ARROW towards Engine.
Cut a section of pipe and see if the inner lining has delaminated. The grey fuel pipe is bad for this. Modern Ethanol fuels damage the lining. Black Tube is best.
Also I had a similar issue on an Evinrude and it was a linkage not connected to the carbs. Only one was actuating.
Check grounds and bad connections as David says.
Boat does not plane
you could try a lower pitched prop.2" would up the revs by 400 revs.,which would up the revs ,but give you more low down thrust,and/or tucking the motor under more[if you have electric trim/tilt].thats a big boat and fair bit of weight for a 40hp..my 40hp merc is on a 13ft saracen,and with two of us it takes a while to get gooing.so i bought a ProPulse prop,with adjustable pitch.been god to try different pitches
Boat motor has no power
boating season is coming again. if your boat motor will not start and it has a shifter box here is your most common problems.
1. the shifter cable has stretched and the neutral position on your shifter doesn't match the neutral position on the motor. this will make the boat think it's in gear which will keep your motor from starting. adjust your cable so it lines up again or replace it if it's too far out.
2. steering is stiff... always grease the rear grease nippers on your motor.. second get a cable sprayer attachment and a can of wd40 .. the attachment slips over the end of the cable and forces the wd40 down the casing.. spray until the fluid coming out of the far end comes out clean . then rehook the cable. do this for your shifter and acceleration cable if you have the duel type. bike shops carry the required tool.
3. replace the leg oil and if it is a 4 stroke the engine oil.
4. replace the spark plugs and carry a spare set +tools required to remove them.
5. check your batteries and make sure they are topped up. a small 40 watt trickle charger is an excellent addition. while your there check to see if the connections are tight and clean on both the motor end and the engine end.
check your bilge pump to ensure it is working.
6 make sure you carry a few spare fuses... I keep a package of mixed on board.
7. make sure your water pump is spitting out a good steady stream. you do this by getting water muffs and supplying water from a garden hose. once water is present and running passed the muffs at a good rate fire up the engine. the stream coming out in the back below the motor should be as steady as a fellow having a bathroom break. if it isn't get that pump replaced.. your motor is expensive.
8. put some spare fuel in a container on your boat.. I lost count of all the guys I towed back.
9. always carry a manual bailer , paddle, whistle , and flashlight with fresh batteries. and let some one know where your going and when you expect to be back.( I also carry dry clothes in a sealed vacuum bag , rain gear and most important 2 jugs of freshwater)
have fun and be respectful.
Mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
Electric fuel pump will not turn
The motor has been sitting for a while and you try and start it... everything clicks but the electric fuel pump doesn't spin the whirl sound... first take your fuel system apart and clean it with sea foam a.d never carb cleaner as it is ******* seals and rubber, plastic etc. the boat mechanic will tell you you need a new 400$ pump... try this soak the fuel pump almost 3/4 submerged in an non aggressive cleaner like sea foam for 3 days... dry it, pull out the old heat gun and heat the side to a point where it is almost too hot to hold by hand.. Remember to keep waving the heat gun and rotating the pump. Then attach two small wires to the top of the pump where the electric powers it up... I use the red and black were from a electric tester ( the one with the dial . The end that hooks to the tester will fit perfectly over the blade on the fuel pump. And the probe end can easily touch the posts on a 12v battery.... so have this wire ready cause you have to move fairly fast. Once the heating is done place the wires on the fuel pump, and begin to touch the post of a 12v car battery with the two probes.. one on positive one on the negative side for 1 second then reverse the probes to the opposite post... for 1 second until the pump frees.. or 1 min passes... if it breaks free run some fuel through until it stops spitting out debris, if it doesn't tap the sides sharply with with a hard plastic hammer ( not steel) you must not hit it hard enough to dent it... re heat and try again.. it sounds like it's trying to spin but will not... soaked it again for 3 days and repeat. I haven't had that trick fail yet. .. ps.. if your seals are not quite fitting properly.. place them on a flat piece of white paper and let them dry for a day or two.. they will shrink.
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
