20 Most Recent Flow M9 Snowboard Binding Questions & Answers
tip
Wax your ski and check that the pole lish is strong
before every ski vacation
make sure your ski is waxed enough and that the hand lish ia stron enough
Broken cable cant release old
Does this help you.
http://www.hittingkickers.com/setting-up-flow-bindings/
http://360guide.info/snowboarding/snowboard-binding-mounting-instructions.html
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
2/6/2011 1:14:25 AM • Flow M9... • Answered on Feb 06, 2011
Too much forward lean on my highback
Yes most binding are like this because it helps you to get a good heal edge and faster transfer from edge to edge. It is something you will get used to but if your more interested in having a soft high back then talk to your local store about this exact problem and see what they have.
6/8/2010 8:53:05 AM • Flow M9... • Answered on Jun 08, 2010
Snowboard binding
No womens large bindings are rated womens size 8 or larger, and mens 7-9. If you have burton bindings you can shorten the adjustable strap. but make sure you strap in and when you crank down the straps you should not be able to move your boots or wiggle them around.
3/11/2009 7:19:19 AM • Flow M9... • Answered on Mar 11, 2009
Snowbard bindings adjustment
"With everyday use, the screws, nuts and bolts that hold the highest stress areas together tend to loosen up. Consequently, they need to be tightened regularly to ensure that a strap doesn't fall off and get lost. However, not every Mountain Resort provides tool stations, so it's important to have a Snowboard Tool within reach (preferably in your pocket) at all times. Remember, a snowboard tool is a small investment that will definitely pay off over years of riding. Also, with the standardized insert pattern of snowboards, and with the built-in adjustment capacity in most Bindings, Mounting and Adjusting Bindings has become simple quite a simple task. To be able to do this, make sure you have a screwdriver and a wrench or two. Also, it would be a plus if you have some basic knowledge about the stance width, stance location and stance angle. The distance between your front and rear foot is the Stance Width. The basic stance width is roughly the length of your shoulder-width apart (about 30 per cent of your height). The location of the center point between your Bindings relative to the center of the snowboard is the Stance Location. Conversely, the angle of the Bindings across the snowboard's longitudinal axis, wherein zero degrees represents a line that is perpendicular to the snowboard's length, is the Stance Angle. * Forward Lean For starters, check your board's Forward Lean. The forward lean is the amount of forward angle on the highback support. For more leverage and more responsive heelside turning, add more forward lean. By adding forward lean, you also force your knees to bend, consequently ensuring a good riding stance. Still, too much forward lean makes your knee bend too much. Over bending your knees put pressure on your quadriceps muscles and reduces your ability to turn easily. So don't overdo it. You can usually adjust the forward lean in soft-boot Bindings by changing the position of a plastic stay behind the highback. * Rotating the Highbacks You can easily rotate your Bindings' Highbacks if your bindings have slots on the hinges where the highbacks are fastened to the binding's baseplate. To make your heelside turning more responsive than when it is angled along with the baseplate, adjust your Bindings in parallel with the Snowboard's Heel Side Edge. You can do this by loosening the bolts and rotating the highbacks. * Adjusting Strap Position Generally, this involves unscrewing the straps from the baseplate and moving them forward or backward on the Bindings. To improve control, move the straps higher up on the foot. Conversely, move them down lower to increase flexibility. Make sure that the toe strap is resting around the base of your toes and is securely holding down the tip of the boot. Shorten your straps if you find yourself pulling on them for a snug fit. You can do this by fastening the straps to the baseplate further along the length of the strap. Most straps already have extra holes for this adjustment."
1/1/2009 10:09:19 PM • Flow M9... • Answered on Jan 01, 2009
How do i know when snowboard bindings are tight enough (hand tightening screws to board)?
I would think that you could pull out the inserts or break a screw if you got them too tight. I would suggest only using a screwdriver type handle for tightening - no ratchet or other leverage. Just get them as tight as you can with one hand and you should be OK. They don't really need to be that tight - it is more coming apart that is the problem. The other problem is rusting. Both of these problems can be solved by using a high quality tread locking compound - the best is LocTite. Most stores that carry hardware will carry threadlock compound - this will prevent the bindings from loosening up.
12/1/2008 1:20:43 PM • Flow M9... • Answered on Dec 01, 2008
Is there a different type of bindings for each type of riding?
Technical freestyle This type of rider is most often found on the lower elevations of the mountain, hiking the halfpipe or riding in the snowboard park. Many of today's technical freestyle riders come to snowboarding with experience as a skateboarder, in-line skater, BMX, or other action sports background. While the equipment specific to this type of rider excels in park and pipe riding, it can also be very versatile across the whole mountain at less than full-speed. * Technical freestyle bindings o Technical freestyle bindings generally use a low hiback with 2 straps for increased flexibility and range of motion o These bindings are not usually value/price driven o Most technical freestyle bindings (either step-in or strap) are made of composite materials in vibrant colors o Riders generally gain responsiveness with a minimal weight gain Freeride While an overused term in snowboarding, freeride is still the best way to describe the majority of snowboarders and soon-to-be snowboarders. As it suggests, freeride describes a user who intends to utilize the whole mountain. These riders enjoy everything about snowboarding: the amazing feel of carving a turn on freshly groomed slopes, the sense of flight obtained at lift-off from the big-air jump, the creativity that can only be understood descending the half-pipe, and the feel of freedom one gets floating in fresh powder. * Freeride bindings o Freeride bindings generally have higher hiback with 2 or 3 straps for added support and control o These bindings come in every shape, color, and price o For the most part, no matter what the specifics of each freeride binding, the general effect on the riding experience is minimal. This holds true for both traditional/strap bindings and Step-In bindings. o Binding choice is commonly a packaging decision or one of brand/price/graphics Freecarve This type of riding style is one of the fastest growing segments within the snowboarding world. Commonly referred to as "cross-over," a majority of these riders were once skiers. A freecarve rider enjoys the full-length and width a mountain has to offer, continually transitioning from one turn to the next. * Freecarve bindings o As with freecarve boots, there are very few freecarve bindings o Those that are freecarve specific can usually be distinguished by their third strap o Step-In bindings are also available in a freecarve configuration, and are almost always manufactured from space-age composites Alpine/Race Alpine/Race riders are easily picked out of the crowd. They are always seen on groomed trails, laying a trench in the snow with each turn. These riders use a snowboards edge like no other rider. Using powerful body movements and gravity as their friend, alpine riders enjoy the sport only when they are connected to the snow. * Alpine/Race bindings o Alpine/Race bindings are usually a plate binding with hard boots o Metal and composites are the only available materials for this type of binding
12/1/2008 1:20:42 PM • Flow M9... • Answered on Dec 01, 2008
Snowboard bindings types
"Strap Bindings Highback Bindings The Strap Bindings is the original and still the most popular Binding System in Snowboarding. This is because Strap Bindings are not only adjustable and very secure, they are also comfortable. Nowadays, this Type of Bindings is designed to be lighter and stronger. Strap Bindings consists of a contoured baseplate where a rider can place his Soft Boots upon. At the back of the baseplate is a vertical plate (the highback) that rises behind your ankles and lower calves. The highbacks on Snowboard Bindings secure the heel of your feet and the backside of your lower legs. It also helps you to force the heel side edge of the board into the Snow Surface and brings the toe side of the board up. At the front of the binding are two or three adjustable straps which can be used to secure the front side of your feet and ankles to the Snowboard. Initially, you may have to sit down to strap in, but with a bit of practice, it'll be easier to strap in while standing. Strap Bindings can differ in the number of straps, the shape of the base, and highback plate. Alpine riders who need to perform high speed turns will prefer taller and stiffer highbacks for greater control and improved edge control. On the other hand, Freestylers will want a shorter backplate for more flexibility and turning power. Most people go for these kinds of bindings as they are more common, offer excellent control, and offer more options when it comes to boots-bindings combinations. The combination of the highback plate and the front side straps gives great control. This Type of Bindings is used in combination with Soft Boots. As the Binding gives all the support needed, the Snowboard Boots can remain soft and comfortable. Keep in mind that the Best Strap Bindings have ample amounts of wide padding at the toe and ankle straps. Step-In Bindings Step In Bindings It is quite hard to get into Strap Bindings since you need to loosen and tighten the straps every time you get into and out of your bindings. This is why Step-in Bindings were developed. This Type of Snowboard Bindings allow you to simply step down and click into it, thus making it easier for you to get on and off your snowboard. With this feature, Step-in Binding Systems have become quite popular with rental shops because they often give the beginners fewer Snowboard Equipment to fuss with. Still, while Step-In Bindings give you additional speed and can save you from a load of hassle, you pay for these conveniences when it comes to snowboard control. Step-in Bindings don't have any straps to give additional support, making the Snowboard Boot less flexible, and thus, harder to do Snowboarding Tricks. So make sure you get a good fit if you're planning to buy this. Step-in Bindings usually work in combination with soft boots which are somewhat stiffer than those used with highback bindings. When you opt for Step-in Bindings, you narrow your selection in choosing Snowboard Boots and Bindings since they both have to be ""step-ins"". However, there are some higher and more advanced Step-in Bindings out on the market that provide the best of both worlds. Step-ins can be used for either Freeride or Freestyle riders. Cross-over skiers will often feel comfortable with Step-in Bindings and boots since they are used to stepping in and to harder boots and just turning a switch or a latch whenever they want to get out. Flow-In Bindings Flow In Bindings Flow-In Bindings is quite new and is a hybrid of the step-in and strap systems. This Type of Snowboard Bindings tries to combine the control of Strap Bindings with the ease of Step-in Bindings. Flow-In Bindings look rather similar to Strap Bindings and also allow you to use soft boots. The notable difference is that, unlike the two or three straps that cover the top of your feet in Strap Bindings, the Flow-in Bindings have only one large tongue that covers a large part of the top of your Snowboard Boot. Getting into and out of your Bindings is a matter of flipping the highback backwards and entering or exiting your boot. Flow-in Bindings are becoming more popular as the choices and Techniques of Snowboarding improve. People love the Flow-in System as it combines all the advantages of the Strap Bindings with the ease of Step-ins. One disadvantage however is that Flow-in Bindings are more difficult to adjust than strap-ons. Plate Bindings Plate Bindings Plate Bindings, also known as Hard-Boot Bindings, consist of a hard baseplate, steel bails, and a heel or toe lever. This Type of Bindings is used in combination with Hard Boots that can be inserted into the bails. By flipping the lever, the boots are strapped firmly into the Bindings. The features of the Plate Bindings are the closest to a traditional Ski Binding and their rigid responsiveness provides maximum leverage and power for high-speed carving and riding on hard snow. Plate Bindings and hard boots are mostly preferred by Alpine Racers who need the extra edge control that they get from this combination. Baseless Bindings This Type of Bindings was introduced in the mid 1990's by several companies. In Baseless Bindings, the sole of the Snowboard Boot is placed in direct contact with the Snowboard deck by removing the Binding's baseplate. With this, the sole height is lowered by up to 1/8 of an inch. Theoretically, using the Baseless Bindings enhances the ""feel"" of your Snowboard's flex. However, this Type of Snowboard Bindings aggravates ""toe drag"" problems for people with large feet. Also, most Baseless Bindings are far more difficult to adjust (stance angle/width) than traditional ""4x4"" designs. Still, Halfpipe and park riders prefer Baseless Bindings because it provides them with a quicker edge response. The choice of what Type of Snowboard Bindings to use usually comes down to personal preference and finding the right Snowboard Boot first. If you feel that the convenience of stepping in outweighs the additional control you can gain, then it is best to go for that particular Style of Binding. Regardless of which Type of Binding System you wind up with, don't head for the slopes until you know exactly how to get in and out of them. With or Without Highbacks? The large curved piece of plastic screwed to the base of the binding is the Highback. Its main function is to give riders some control over their Snowboard's Heel Edge. These can be found on all Bindings or are built into the boot with some Step-in Systems. Alpine riders who need to perform high speed turns will prefer taller and stiffer Highbacks for greater control and improved edge control. On the other hand, Freestylers will want a shorter backplate for more flexibility and turning power. Snowboard Boots and Bindings form a combination wherein not all Kinds of Bindings are suited for each type of Snowboard Boot. It is often best to buy them together. In here, knowing your intended Snowboarding Style is crucial before buying a combination of boots and bindings. "
I got a frayed flow boa lace cable is it fixable? frayed and brok
usually once there dead they need to be replaced, wait until the day they break or it annoys you enough to buy new ones.
2/5/2010 2:21:37 AM • Flow Winter... • Answered on Feb 05, 2010
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
2answers
Spark plug gap on a 2006 Polaris 700 Classic
It depends on the brand of spark plug you are using. https://www.google.com/search?q=2006+Polaris+700+Classic+spark+plug+gap ..
12/18/2022 3:53:35 PM • Winter Sports • Answered on Dec 18, 2022
2answers
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
2/24/2022 9:59:23 AM • Winter Sports • Answered on Feb 24, 2022
2003 Ski-Doo Grand Touring 550 Fan. All of a sudden I have no spark! What could be the problem?
kill switch --ign switch--cdi--magneto--broken wire --etc https://ski-doo-snowmobile.brssm.com/ https://www.snowmobilerepairmanual.com/ski-doo-repair-manual/
1/16/2022 5:08:05 PM • Winter Sports • Answered on Jan 16, 2022
Skandic Skidoo. How do I take out a battery that is located underneath the seat of a Skandic Skidoo
Question edited for clarity. Question moved from Seat Cars (Spanish car maker and pronounced See-at) to Snowmobiles Category. The are videos and text based articles. The best bet is to fit pigtails to the battery and had a plug for a battery maintainer. You never have to remove the battery, and you never have to worry about it it not being charged. https://www.google.com/search?q=skandic+skidoo+remove+battery ..
1/15/2022 10:33:14 PM • Winter Sports • Answered on Jan 15, 2022
2012 Switchback adventure 600
MAYBE IT NEEDS SOME OIL ADDED
1/4/2022 7:51:27 PM • Winter Sports • Answered on Jan 04, 2022
3answers
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
6/25/2021 3:58:02 PM • Winter Sports • Answered on Jun 25, 2021
1991 Polaris Indy 500 Classic. How do you remove the chain case? It seems to be holding on the top?
I fixed the question and put you in the Snowmobile category Video instructions here https://www.google.com/search?q=1991+classic+500+replace+chain ..
6/4/2021 3:46:08 PM • Winter Sports • Answered on Jun 04, 2021
2007 Arctic Cat F1000. Why does it keep stalling while being ridden?
It could be many different items, choke stuck, ignition switch etc. but more importantly have you taken care of your recall? https://www.cpsc.gov/Recalls/2017/Arctic-Cat-Recalls-Snowmobiles
4/29/2021 5:05:37 PM • Winter Sports • Answered on Apr 29, 2021
Flow M9 Snowboard Binding Logo
14 questions posted
Top Flow Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Flow Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
Flow Winter Sports
  • Flow Winter Sports
Most Popular Question
know when snowboard bindings tight enoug
  • Winter Sports
