20 Most Recent
Mountain Trek Fisher Bike Derailleur Hanger, Fuel, Lemond 6 Questions & Answers
The derailer front and rear move only two cogs
Take your bike to a Trek Dealer, you can cause more damage if it is loose or too tight. You have a good bike, don't skimp and have someone "fix" it that really does not know what they are doing. I've seen many that the owner's buddy "fixed" and it always means more work and more expensive because we have to undo the damage first
Need to no year make and model of trek bike bye
Hi
Trek's serial numbers are on the underside of the bottom bracket. Flip the bike over and read the letters and numbers. It will look like this :
9000697000480
This would be a Trek 9000, made in June 1997 and number 480 off the production line.
Hope this makes sense and you can decipher your bike. Vote for me if this helps, thanks.
What size is my bottom bracket for a Nishiki Kinzua 29 Men's Mountain Bike
hi if i remember correctly to size up for a bottom bracket, flip your bike upside down resting on handle bars and seat carefully not to damage anything, and where the bottom bracket go's through the frame of the bike you take a tape measure and measure the width of only the frame housing where the bottom bracket go's into this is a lot easier to do when the crank arms are removed. also on some bottom brackets when removed from the bike has all the data stamped on it depending on the type of bottom bracket. if not measure the width of the frame where the bottom bracket sits in too and that will be the size of the bottom bracket you need, then determine which type it is once you have remove the cranks arm which are attached to the bottom bracket could be splined drive or square tapered type bottom bracket basically the shape of the metal part that the crank arms push and bolt on to then match up on a cycle part website.
I need disconnect front wheel mountain bike forfringe super cycle 550 zoom full suspension
The front wheel is normally held in with one of two common methods. A basic nut on each end of the axle or a 'skewer' pin. On most bike that do not have disc brakes you might need to unhook the brake arms to allow the tyre to clear the brake pads.
For the nut type simply slacken the nuts and drop the wheel out of the C shaped notches the axle sits in.
The skewer type is a small lever on one side you swing all the way over then slacken the nut on the opposite side two or three turns. The wheel should then drop down and out.
Need an owners manual for a 26” Women’s Nishiki Pueblo Mountain Bike
That bike was made from 1993-1998. It's a standard Cro-Moly (i.e. Steel) non-suspension mtn bike. In other words, there is nothing unique about it that would require an owner's manual. I might suggest you post the actual issue with the bike to get some feedback as to how to deal with it.
