20 Most Recent
Mountain Prowheel Bicycle Crankset Bike Parts 286 Questions & Answers
I have a mountian bike
Missing? Like fell off - or was never there? Do some search engine stuff and find out what that part is called. Maybe 'crank''? Then ask someone at a Local Bike Shop to fix you up. No one sells just one crank.
7/11/2011 8:39:59 PM •
Mountain...
Answered
on Jul 11, 2011
I recently just bought a
You don't give any specs for your particular crank but if you Google it you will probably find an entire crankset for less than a shop would charge you to chicken wire yours, if indeed they would even consider it. Left-hand thread complicates it.
For example...
http://www.downtube.com/product515.html
Or look on eBay.
6/3/2011 9:31:55 PM •
Mountain...
Answered
on Jun 03, 2011
The Left Pedal is striped
If all of the threads are stripped out of the crank arm, then what is known as a "helicoil" is the only thing you can do to fix it, aside from getting a new crank. Putting in a helicoil takes someone who knows how to do it, BTW. Take it to a bike shop where you can get help with it.
1/12/2011 6:49:38 AM •
Mountain...
Answered
on Jan 12, 2011
What size is my bottom bracket for a Nishiki Kinzua 29 Men's Mountain Bike
hi if i remember correctly to size up for a bottom bracket, flip your bike upside down resting on handle bars and seat carefully not to damage anything, and where the bottom bracket go's through the frame of the bike you take a tape measure and measure the width of only the frame housing where the bottom bracket go's into this is a lot easier to do when the crank arms are removed. also on some bottom brackets when removed from the bike has all the data stamped on it depending on the type of bottom bracket. if not measure the width of the frame where the bottom bracket sits in too and that will be the size of the bottom bracket you need, then determine which type it is once you have remove the cranks arm which are attached to the bottom bracket could be splined drive or square tapered type bottom bracket basically the shape of the metal part that the crank arms push and bolt on to then match up on a cycle part website.
I need disconnect front wheel mountain bike forfringe super cycle 550 zoom full suspension
The front wheel is normally held in with one of two common methods. A basic nut on each end of the axle or a 'skewer' pin. On most bike that do not have disc brakes you might need to unhook the brake arms to allow the tyre to clear the brake pads.
For the nut type simply slacken the nuts and drop the wheel out of the C shaped notches the axle sits in.
The skewer type is a small lever on one side you swing all the way over then slacken the nut on the opposite side two or three turns. The wheel should then drop down and out.
Need an owners manual for a 26” Women’s Nishiki Pueblo Mountain Bike
That bike was made from 1993-1998. It's a standard Cro-Moly (i.e. Steel) non-suspension mtn bike. In other words, there is nothing unique about it that would require an owner's manual. I might suggest you post the actual issue with the bike to get some feedback as to how to deal with it.
