20 Most Recent
Avermedia AVerKey Plus (AVERKEY-PC) Questions & Answers
AverKey3 Plus
Hi, sorry to tell you this, but static electricity has killed every conceivevable type of electronic device ever built by man or woman. The insides of your TV has very high voltage and the only safe solution is to take it to a repair man. Ask for a qoute before any work is done, try to get at least 2 quotes.
It may be cheaper to replace than repair the unit and with 2 quotes you will know that you are not being conned.
Regards mistyman
12/6/2008 6:13:59 PM •
Avermedia...
Answered
on Dec 06, 2008
Averkey
Unit powers up but will not show a picture on the TV. Was working previous day. I have check all cords and even replaced them with ones from another averkey but still no picture.
10/16/2008 3:35:08 PM •
Avermedia...
Answered
on Oct 16, 2008
Avermedia Aver3d Capturehd Hey, I have problem
You must specifically run the driver and software installation as Administrator. While it may appear the automatic process did this, it really didn't.
Right-click on the installation EXE and select "Run as Administrator".
11/1/2017 10:10:49 AM •
Avermedia...
Answered
on Nov 01, 2017
Voice -yes
picture -no
if its your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or
update driver
hope this helps
2/9/2011 9:34:11 PM •
Avermedia...
Answered
on Feb 09, 2011
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?
It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.
The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DYI or replace with good used unit.
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV.
On your Sky Remote, press the TV button.
Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice.
Enter one of the following 3-digit remote codes for Sky TV:
2274
2169
1874
1798
1872
1873
The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code.
Press the Standby button on your remote. If your television turns off, press the Select button to save the setting.
Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful.
Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how:
Repeat steps 1 to 3.
Enter the 4-digit Sky remote code for your TV brand.
Press the Standby button. If your TV turns off, press Select to save your settings.
Check if the TV Guide displays successfully on the screen.
Sky TV Remote Control Codes
