20 Most Recent
KitchenAid KUDS01FKSS Dishwasher Questions & Answers
Water collects in dishwasher tub
I believe there is a float on the affluent pump like a sump pump that could get hung up maybe some food particles or something built up underneath it and not allow the water to go all the way down.
Water fills and cycles fine. Arms do not spin; no
Either the motor or chopper is broken. If chopper is broken the screen will be clogged with food. If its clgged you can clean it and reinstall and see if theres any improvement. If so replace chopper.
Isn't getting any water to you turn it on
Check the water inlet solenoids...they often get "stuck" a careful "Whack" with something suitable, will often "Un-stick" them. Otherwise you have some sort of fault, that is NOT allowing the water to go in to the unit, because the machine has a fault.
Diswasher
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
