20 Most Recent
Krups GVX1 Electric Burr Grinder Questions & Answers
How to disassemble GVX1 burr
Remove grind selector and # of cups dials, just pull it off. The grind selector dial has a spring loaded detent, the spring will come loose, try not to lose it as well as the detent "plunger" (the piece that engages the dial detents).
The outer housing can slide off the inner chassis, there are four detents located in the vicinity of the four foot pads, use something like a small screwdriver to pry apart the inner and outer plastic parts and pull apart. You may have to loosen one corner at a time, when the last detent releases the outer housing slides up and off easily.
Krups gvx1 complete disassembly
If you can't figure out how to diss-assemble the device yourself, I recommend that you take it to a proper service shop, making sure you call a few of them in your area and find out if they charge for inspection and estimates of repair, then see which one has the best estimate.
Does not turn on!
With the top sensor- I found with mine the pin was missing that actuated the top cover switch in th fill area right side you'll see a small pin hole. All I did was remove the side cover and jump out the switch via solder connection. The side cover has (4) click locks on the bottom that hold it on then it slides up and off. I know its a safety switch but it was more of a pain than a help.
