20 Most Recent LG WT1101CW Top Load Washer 4.3 Cu. Ft Questions & Answers
LG WT1501CW washer rotor is stuck and can't get it off
I am not sure what you mean by rotor. Are you talking about the drum? There is a nut on the top of the splined shaft that holds the drum down. Parts for LG WT1501CW: Drum and Motor Parts - AppliancePartsPros.com
7/9/2022 1:08:21 PM • LG WT1101CW Top... • Answered on Jul 09, 2022
How do you remove the main pcb in a LG WT1101CW washing machine?
Hi Glenn, Here is a link pertaining to your question. I have also included a video link for the same. Good luck, JP https://www.manualslib.com/manual/1070821/Lg-Wt1201c-Series.html?page=20#manual https://youtu.be/IaTIbqolt_E
6/22/2019 8:38:17 AM • LG WT1101CW Top... • Answered on Jun 22, 2019
UE Error code on LG WT1101C
Unbalanced Error. There is a download from LG that addresses this known issue. Call LG. Ask about software/firmware download.
2/27/2017 5:50:54 AM • LG WT1101CW Top... • Answered on Feb 27, 2017
0answers
Why are the cycles so long, like almosr an hour?
water efficiency requires longer running cycles.
11/28/2015 12:35:25 AM • LG WT1101CW Top... • Answered on Nov 28, 2015
0answers
0answers
I have LG washer wm2016cw got OE code. I am attempting to remove the drain pump filter. I removed the drain filter cap, but the filter is did not come out. Is their a trick to get the filter out.
To remove the drain pump filter on your LG washer model WM2016CW, try gently wiggling and pulling it after removing the cap. If it's stuck, apply lubricant sparingly and tap around the edges. Comparing with your mother-in-law's similar model might offer insights. If all else fails, refer to the manual or contact LG support for assistance.
4/11/2024 4:51:23 PM • LG Washing... • Answered on Apr 11, 2024
LG Fuzzy Logic 8.2kg WF-8071TTP washing machine doesn't dissolve the soap and leaves marks on the clothes.
You are using the wrong type of detergent. Use liquid instead of granulated powders. They don't dissolve in low temperatures. https://www.manua.ls/lg/wf-8071ttp/manual?p=8 ..
4/7/2024 7:25:34 PM • LG Washing... • Answered on Apr 07, 2024
A new LG dryerDLE7150W. It will run for 10 minutes then shut off and have a nP code. checked everything from the panel to the cord connections and it is good.. I have 221c at the outlet. any clue?
An nP display code indicates that there is a problem with the electrical wiring in the home and that no current is being detected at the heater.
2/8/2024 3:03:16 PM • LG Washing... • Answered on Feb 08, 2024
I have a LG WM2688HWM washing machine with a spin problem.
This has a new fangled direct drive motor. Normally the fix would be to replace the motor controller or one of the capacitors on the board, but this has none of those, and appears to be run by one control board and that is no longer available. Try cleaning the connectors to the control board with electrical switch cleaner spray. Your best bet is to call for service and hope they can replace the part that is preventing the spin cycle. https://www.searspartsdirect.com/model/1nx1gwawbm-003204/lg-wm2688hwm-washer-parts Some videos on that issue ..
2/1/2024 4:26:00 PM • LG Washing... • Answered on Feb 01, 2024
LG WM2010CW won't spin: Error code In:81, IU:00
check belt if ok check under agitator possible bad cogs
12/8/2023 9:15:32 PM • LG Washing... • Answered on Dec 08, 2023
I have a problem with my dishwasher LG 425. It shows an error at the end of the washing process. The error is BE. What is it related to?
Wrong washing deterjant being used and machine not leval . Google your machine with the error code and you find a u tube link on this that will help you
12/7/2023 11:19:05 PM • LG Washing... • Answered on Dec 07, 2023
LG LMN187HVT Mini Split Heat Pump. Error codes for it please?
Question edited for clarity and toss in some CAPS.
DEFINING COMMON ERROR CODES
LG HVAC https://lghvac.com > resource-service > filenam... LED2. (Cooling LED). 1. Indoor unit return air thermistor has disconnected or has shorted out. 1X. -. 2. Indoor unit inlet pipe thermistor has disconnected ... 2 pages https://www.google.com/search?q=lg+lmn187hvt+error+codes ..
12/1/2023 11:54:25 PM • LG Washing... • Answered on Dec 01, 2023
LG WT1101CW Top Load Washer 4.3 Cu. Ft Logo
15 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
oh washer rotor stuck get off
  • Washing Machines
