20 Most Recent Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White Questions & Answers
WASHER WON'T START
Thank you for your inquiry, friend!
I see that you are having trouble with your Frigidaire washer not starting. This sounds like a possible problem with your control panel or keypad. You may need to disassemble the washer in order to pinpoint the possible problem this is not a simple DIY job. I would recommend seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid future issues as well as possible multiple part purchases. I hope this information is helpful. -Matt
4/22/2015 2:49:37 PM • Frigidaire... • Answered on Apr 22, 2015
Frigidaire stack dryer turns off after few seconds
CHECK MOISTER SENSOR AND OR THERMISTOR. THERMAL CUT OFF AND CYCLING AND HI LIMIT THERMOSTATS
4/1/2015 12:44:41 AM • Frigidaire... • Answered on Apr 01, 2015
0answers
2answers
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you! I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
3/20/2024 3:24:35 AM • Frigidaire... • Answered on Mar 20, 2024
Frigidaire Front Load washer (25 yrs old) fills completely but does not spin for the wash cycle. Manual timer clicks and buzzes but drum does not spin nor does the timer advance.
Sure sounds like your timer has bit the dust. I'm not sure if the timer is still available. You have a great washer there. Good luck.
2/11/2024 4:24:20 PM • Frigidaire... • Answered on Feb 11, 2024
My Frigidaire FWAC 19B5MSGNW washing machine won't move on from the spin cycle. The light is on and if I fill it up with water it will pump out the water but the spin light will not come off.
The machine does not exist as you have written it. There are two likely reasons The door switch has failed and hasn't passed the self test procedure. or the control board / timer has failed. Try power cycling it. Remove the mains plug for an hour. It is has an On Off button press it for a minute. For a knob, full it and leave two minutes. Plug back in and try again. https://www.google.com/search?q=Frigidaire+FWAC+19B5MSGNW ..
1/2/2024 11:12:23 PM • Frigidaire... • Answered on Jan 02, 2024
Frigidaire front load washer door locked
crowbar?
5/15/2023 1:33:24 PM • Frigidaire... • Answered on May 15, 2023
What's stopping my dryer from running continuously
Hi, Please power cycle your dryer and attempt to run it again. If this fails, please ensure that your clothes are evenly distributed so that they weight of the clothes doesn't cause the dryer to be shutdown. Just to double check, please ensure that you've cleaned the lint track of your dryer. Lastly, you can use an power outlet extender to help switch the power outlet that you're using to run your dryer as there might be something wrong with your current one. Thank you.
1/8/2023 1:32:57 AM • Frigidaire... • Answered on Jan 08, 2023
My Frigidaire dryer won't run longer than 5 secs what's wrong how can I fix
There could be several issues that could cause your Frigidaire dryer to stop running after just a few seconds. Here are a few potential problems to consider:
  1. Thermal fuse: The thermal fuse is a safety device that shuts off the dryer if it overheats. If the fuse has blown, the dryer will not run.
  2. Clogged dryer vent: If the dryer vent is clogged, it can cause the dryer to overheat, which could trip the thermal fuse.
  3. Faulty cycling thermostat: The cycling thermostat regulates the dryer's temperature. If it's faulty, the dryer may not run for more than a few seconds.
  4. Faulty start switch: If the start switch is faulty, it could prevent the dryer from running.
  5. Faulty door switch: The door switch prevents the dryer from running when the door is open. If the switch is faulty, the dryer may not run.
To fix the problem, you'll need to diagnose which of these issues is causing the problem and then replace the faulty part. I recommend having a mechanic diagnose and fix the problem for you.
1/8/2023 1:18:38 AM • Frigidaire... • Answered on Jan 08, 2023
3answers
WHAT IS E11 ERROR CODE IN MICROWAVE FRIGIDAIRE
The E11 error code indicates a problem with the gas sensor DE32-60011A and or the wire harness DE39-40678D. Unfortunately the manufacturer has discontinued the sensor. You may want to try contacting local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it or try eBay, Amazon or similar sites . Search by using the manufacturers part number. Try a used appliance store, sometimes they have the same model or a usable part for your machine.
12/23/2022 7:33:43 AM • Frigidaire... • Answered on Dec 23, 2022
Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White Logo
9 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
washer start
  • Washing Machines
