20 Most Recent
Maax Kashmir Bathtub - 100041-000 Questions & Answers
Rotten egg smell in bathroom closet?
I can't tell about your water supply from this posting. Is it possible you have iron or sulfur in your water that only shows up in the hot water? If so, you may not have drained the water heater often enough to prevent problems. Usually, draining it about every 6 months will do it. To drain the water heater, turn off the energy source (electricity or gas), turn off the inlet valve, and connect a water hose to the drain at the bottom of the tank. Open the drain ****. Some don't have handles and require a flat blade screwdriver to open them. Run the drain hose down the driveway so the hot water from the tank doesn't kill your lawn. By the time it reaches the street, it should be cooled off enough not to hurt anything. If it's been a while, you may want to weight down a trash bag at the end of the hose so the water and sediment coming out don't stain your concrete driveway. Let the water from the end of the hose dissipate over the trash bag. It takes about 30 minutes to drain a 40 gallon water heater. It goes faster to carefully open the overflow pop off valve to let air in while it's draining. When it's drained, close off the drain spigot, open the incoming water and when it is quiet again (full), turn the energy back on. You may have to relight the pilot or click the igniter until it flashes one time to let you know it's working. You should have hot water again in about 30 minutes. If the smell in the drain persists, some baking soda and vinegar flush will normally take care of that.
5/14/2019 1:12:24 PM •
Maax Home
Answered
on May 14, 2019
