20 Most Recent Konica Minolta bizhub 750 Questions & Answers
Error c2804
C-2804 While in the gamma correction, the dirt correction of the gamma sensor is not sufficient. When this condition is detected 10 times in succession, the error code is displayed
2/19/2020 12:49:05 PM • Konica Minolta... • Answered on Feb 19, 2020
How do i fix error code c-2401
If you wish to get some details; check the site linked here. Pull up older posts...... http://electro-medical.blogspot.com/
4/30/2019 5:48:27 AM • Konica Minolta... • Answered on Apr 30, 2019
How to reset c3803 code bizhub750
If the code comes back, you need a Fusing unit ( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!! 1. Turn ON the main power switch (SW1). 2. With the Utility/Counter button pressed, turn ON the power switch (SW2). 3. Press [Trouble reset] to release a trouble with [OK] displayed. 4. Turn OFF and ON the power switch (SW2). Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/2/2016 8:28:30 PM • Konica Minolta... • Answered on Jul 02, 2016
What is error code c-2401?
Clean the drum sensor that monitors the drum, and the surrounding area. also has the developer and drum been replaced.to clean the drum sensor the drum must be removed. do not use a vacuum cleaner as static electiricty can destroy the senor, use a clean brush. located under the drum to the rear has a white cover over it, the clear sensor in the middle is for paper jams. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
4/24/2016 11:11:27 PM • Konica Minolta... • Answered on Apr 24, 2016
My machine don'y copy, I receive message:Now warning up. Ready to scan
Sir/Mam, Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/13/2016 10:29:41 PM • Konica Minolta... • Answered on Mar 13, 2016
750 service manual
1/13/2016 11:30:11 PM • Konica Minolta... • Answered on Jan 13, 2016
How to fix it my bizhub 750 appear on screen question mark on 1 and 2 tray
Mean the copier can not figure the setting of the guides in the draws set the guides for the correct papaer Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/29/2015 7:53:46 PM • Konica Minolta... • Answered on Dec 29, 2015
How to fix problem biz 750 code c6708
Exposure lamp that is the bright light under the big glass that come on when scanning, the code also is associated with the CCD that is the device that see's the image you wand to copy or scan again under the big glass to your right, has a lens on it. One or bot are bad. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/25/2015 9:41:55 PM • Konica Minolta... • Answered on May 25, 2015
Web suppply reset
First, Has the web been replaced? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/21/2015 12:53:44 AM • Konica Minolta... • Answered on May 21, 2015
Please any one tell me about this code c-6708 & how can i fix this code
REplace the exposure lamp and CCD (Charge Couple Device) bright light under the big class, or the big black part under the big glass. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/19/2015 3:41:13 AM • Konica Minolta... • Answered on May 19, 2015
I have a problem in bizhub 750 code error c-6708 how can i fix this code error
Might be the Exposure lamp the bright light that comes on under the document feeder make a copy with the doc feeder up does that bright light come on? Or mite be CCD (this is the device that read the original document before it is sent to the LASER) the big black assemble under the big glass. Either one or both mite need to be replaced. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/19/2015 3:39:46 AM • Konica Minolta... • Answered on May 19, 2015
W to reset web supply of bizhub 750 konika minolta
First has the web been replaced. if not going to get bad image problems, have to go to service mode then counters a clear web roller. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/16/2015 10:25:42 PM • Konica Minolta... • Answered on May 16, 2015
What should I do with my Konica Bizhub 750 with the code C 4707
This code relates to the write head. You can try re-seating all the connectors on the pcb (circuit board) or you may have to replace the write unit itself (pn# 57AA-6500). This is not an easy job so if your not a tech and want to keep the machine, you may want to contact a tech in your area for the repair.
3/9/2015 4:52:03 PM • Konica Minolta... • Answered on Mar 09, 2015
Have bizhub 750 and its giving me a code C - C111. Can someone help me please
Have you recently done a firmware upgrade? This code is sometimes linked to the incorrect firmware being applied to the copier.
2/16/2015 3:00:34 PM • Konica Minolta... • Answered on Feb 16, 2015
How to reset c3803 problem, bizhub 750 model
1/16/2014 9:11:03 PM • Konica Minolta... • Answered on Jan 16, 2014
0answers
Bizhub 750
Be the first to answer 10/31/2013 9:15:06 AM • Konica Minolta... • Posted on Oct 31, 2013Be the first to answer
0answers
Error c2804
Be the first to answer 9/30/2013 3:00:50 AM • Konica Minolta... • Posted on Sep 30, 2013Be the first to answer
Code2101
Turn OFF the copier.Press and hold Utility key,turn ON the copier and wait to displayed Trouble reset,touch trouble reset and turn OFF the copier.Wait 2 minutes and turn ON.
1/29/2013 7:52:04 PM • Konica Minolta... • Answered on Jan 29, 2013
Konica Minolta bizhub 750 Logo
Popular Tags
21 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
error code c 2401
  • Office Equipment & Supplies
