20 Most Recent
Konica Minolta Bizhub C224 Color Copier / Printer / Scanner Questions & Answers
How to clear the error
MFP Board
Memory Board/1
Memory Board/2
EIF Board IC-414
Dual Scan Image Board
One of the boards is bad. Recommended that you have a qualified Tech look at the machine. Also might need to have the firmware upgraded. via Secure KMBS web site you can not get. The code is a abort code!
One of the followinf Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Service manual
you may find in internet just type model and you get it
How do I with error C-DC30
Well you hit the "Jack Pot" That code means some one attempted to COUNTERFIET UNITED STATES currency!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!. Some one is in big trouble, There is not a thing you can do. You must get a KONICAMINOLTA Technician out to remove a special chip located inside the machine. It will be sent to KONICAMINOLTA then to the US SERECT SERVICE, since they protect US Money. Once a determination is made as to what happen. A new chip will be issued and new software will be up loaded. UNTIL THEN THERE IS NO RESET!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Btw, I’m available to help over the phone in case u need at
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
P8 error
its a warning p- errors tell you that a consumable is reaching its life such as fuser iu or transfer belllt
