20 Most Recent Bose Solo TV sound system - Black Questions & Answers
4answers
Bose Solo TV unit keeps locking out (no sound) Can
You can go to the repair shop for fix it. Since this unit can be defective by IC, ROM or RAM. or audio circuit+power supply or defective solder.God bless you
2/14/2019 3:30:47 AM • Bose Solo TV... • Answered on Feb 14, 2019
BOSE Solo will not turn on and when it does 50% of the time it produce a "ground noise" sound.
Wall plug--get a two prong into wall socket-- the front has the holes for three prongs also a little eye you can connect a wire to and screw into the screw on the socket plate
7/2/2017 6:22:36 PM • Bose Solo TV... • Answered on Jul 02, 2017
How do i get my BOSE speaker to play my movie dvd's ?? I have picture!!But i just get TV broadcast!
If you don't have a amp that compatible w/ bose...or bose subwoofer you're out of luck
5/23/2017 11:28:39 PM • Bose Solo TV... • Answered on May 23, 2017
2answers
My bose solo has a yellow light instead of green
The yellow light means you are in reduced bass mode. Hold the mute button on the remote for about 3 seconds and you'll hear 3 tones going up and the light will switch back to green. Enjoy!
1/11/2017 9:53:04 PM • Bose Solo TV... • Answered on Jan 11, 2017
Bose solo sound system
Does the Bose remote work at all? New batteries may fix the problem. Logitech Harmony universal home theater remote and app This the best remote control you can ever have for your system. It is amazing. No need to look up codes since the remote is programmed all at once for every component you have and it's done online at their website. Want to change or add a new component? No problem....just log back on to their web site and edit your settings.
9/7/2016 6:44:38 PM • Bose Solo TV... • Answered on Sep 07, 2016
Can you turn it on without the remote? My dog got a hold of the remote and I need to turn it on so I can try to program it to our cable remote.
Learn To Bose Solo TV Sound System 44902 - YouTube
? 2:12 https://www.youtube.com/watch?v=QQziZ3w6z0A Jun 22, 2015 - Uploaded by Lisa Tiffany Knowles Learn To Bose Solo TV Sound System Review Read More reviews from Amazon Buyer: ... I received this sound system withno knowledge of what it really is. ... The rep that I worked with (they assign you one person to talk to--a real. live person who emails you ... bose solo tv sound system universal remote
Solo 15 II TV sound system - Bose product support
worldwide.bose.com/.../en_us/web/solo.../page.html
Bose CorporationThe Solo 15 and Solo 10 series II systems dramatically improve television sound. ...Follow these steps to program your Bose® universal remote to control the other ... high quality home theater sound from your Bose system, you should turn off
7/2/2016 1:57:23 AM • Bose Solo TV... • Answered on Jul 02, 2016
No power to my Bose solo. have installed a new 2032 battery but unit will not come on.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
5/7/2016 3:28:44 PM • Bose Solo TV... • Answered on May 07, 2016
Can I set my youview remote to control the Bose system power and volume
NO. its not possible If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
5/5/2016 5:35:34 AM • Bose Solo TV... • Answered on May 05, 2016
After a few seconds the system loses sound and a loud vibrating sound takes over. When this happens, the remote does not work. Have to turn off at mains.
main amp circuit fault. Check and replace damaged components. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
5/2/2016 12:58:50 PM • Bose Solo TV... • Answered on May 02, 2016
Sound stopped mid program cannot get it to work--replaced and cleaned battery compartment to no avail.
Try going to the BOSE webside where you can use their manuals, or videos or get in touch with their Contact Us tab Bose Solo TV sound system Bose Product Support
4/9/2016 4:22:56 PM • Bose Solo TV... • Answered on Apr 09, 2016
No power to my bose box?
Check the fuse. Take a look at the youtube video on another model Bose3-2-1... It might help you. you should get local fuse depending on your country voltage
3/8/2016 6:12:55 PM • Bose Solo TV... • Answered on Mar 08, 2016
Can I use my BT youview remote to control my Bose solo,if so what is the code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls. Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
2/27/2016 9:16:00 AM • Bose Solo TV... • Answered on Feb 27, 2016
Will not power up
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
2/12/2016 2:27:50 PM • Bose Solo TV... • Answered on Feb 12, 2016
2answers
The sound system was working this morning. Now is has no sound. Tried two different remotes and checked batteries.
Unplug Boso Solo unit for 5 minutes; then plug back in. You should hear a two-tone audio tone.
1/18/2016 4:47:21 PM • Bose Solo TV... • Answered on Jan 18, 2016
2answers
The remote will not turn on the Bose System intermitently.Need to turn the power off for TV & Bose unit & then back on for it to work.
If your system is plugged into a surge protecter, the Bose service guy told me that sometimes the Bose system detects a surge and automatically shuts down. Unplug the system for 5 minutes and then plug back in. This works because it happened to my system. I called Bose and this is what I was told. It worked!
11/22/2015 6:06:07 PM • Bose Solo TV... • Answered on Nov 22, 2015
Bose Solo TV sound system - Black Logo
137 questions posted
Top Bose Televison & Video Experts
Paul Bade
john h
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Televison & Video
Most Popular Question
after few seconds system loses sound
  • Televison & Video
