tank water heater? if so its because the water is much colder this time of year. water heater has to work harder to heat 40deg. water than 70deg. water in the summer. That also means as you use the hot water from the tank its replaced with very cold water. Causing you to have less hot water. Either get a larger water heater. Or even better go tankless and have never ending hot water and save money at the same time.
I suspect the gas control valve is bad, and possibly the ECO and FVIR sensors shorted. Repairs might require replacing gas control, eco, fvir, igniter, and then clean burner and combustion parts. Open following link to identify typical gas valves: and possibly read service manual for troubleshooting that model. http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Take a moment and rate answer: And take advantage of fixya expert assistance live. For a price, expert works with you while you work on water heater or any do-it-yourself project. Fixya is always less expensive than a service call.
Identification of product is needed, then add a comment for possible help. You have tank-type gas water heater.
What did you do to set water heater in vacation mode?
The three most common reasons for this happening to you are 1) a defective gas valve, 2) a rusty thermopile, and/or 3) the automatic shut-off not working as it should.
So, the most common reason for many people having this problem stems from having a gas valve that is not working as it should. When your gas control valve is faulty, it will mean that your burner is not going to be igniting as it should-or at all.
Something that worked for me one time was to turn the Temp all the way down then all the way to Max a couple of times..gradually.
Why it worked I don't know. Got a couple more years out of it though. Good luck!
Best to you.
Rheem furnace error code 68 is a mechanical relay system which signals the blower motor to stop because it has not received a signal from the thermocouple.
Jul 20, 2022
ManualsLibhttps://www.manualslib.com > Rheem-96v-Series
Motor Power And Communications Issues (Fault Code "68"); Line Voltage And Low Voltage Connections To The Communicating Motor - Illustrations - Rheem 96V Series ...
The burner cover plate for your Rheem RRNL-B030JK08E unit can be obtained from an authorized Rheem dealer or distributor. You can visit the Rheem website to locate a dealer or distributor in your area. Alternatively, you can contact Rheem customer service for assistance in obtaining the burner cover plate. Be sure to have the model and serial number of your unit available when contacting Rheem customer service.
From what I'm seeing this means that there is a bad part within your furnace and it needs to be replaced. It might be the thermostat. You might need to reach out to a local HVAC company to diagnose the issue in person.
Thank you.
the gas valve can be replaced, but you will have to pay for installation. this is not a DIY. You can throw money and parts at it. Personally I've replaced my water heater at the first sign of problems. Are they inexpensive no If you furnish model number I can look further.
if system is new call whomever installed it and it repaired under warranty. there are several reasons unit is not producing hot water. First thing I would check is temp setting. Again call for service under warranty.
